Thread: Prelude not getting spark, I have fuel
    Default Prelude not getting spark, I have fuel
    Tdurr and I just finished the swap (dohc f20a obd1) into a 96 (obd2a) Prelude.
    Im getting fuel, but no spark. what should I be checking? I'd love to get this cranked tonight.
    <--- RIP :,( psycho_freke's Avatar
    Locust Grove
    Timing?
    I would be willing to bet you didnt exted the sensors from the crank to the obd1 distributor...
    I did, Rywire harness. You'll have pm.
    icm, coil, or you need a new distributor
    About to approach beast mode
    9 rpm
    Check your ecu. My integra gsr didn't have any spark so I replace the distributor but then it wasn't the problem so I got a new ecu it crank right up. If that help. I could be wrong.
    Just incase someone searches this, Here's what I figured out...
    Rywire sends a jumper wire with the harness. I didn't pay attention to that. It jumps 2 pins from where the external coil used to plug in. I ended up using a 20amp fuse, electrical taped the shit out of it. Cranked right up.
