Results 1 to 4 of 4
Thread: FS: CAR AUDIO. bunch of wiring harnesses, remotes, rca's, turbo timer harness, etc
    02 WRX patrick4588's Avatar
    warner robins
    Default FS: CAR AUDIO. bunch of wiring harnesses, remotes, rca's, turbo timer harness, etc
    I have a box just full of car audio stuff laying around. Most of it I will never use since I am not installing stuff anymore. All prices are shipped. Products Brand New unless stated otherwise. I have the following:
    4 Sony Remotes - $5 each
    2 Pioneer Remotes - $5 each
    1 JVC remote - $5
    1 Apexi DVD remote - $5
    (1) Honda/Acura wiring harness. 70-1720 - $4
    (1) Toyota Wiring Harness 70-1761 - $4
    (1) Chrysler/Plymouth/Dodge Wiring Harness. 70-1817 - $4
    (1) GM Wiring Harness 70-1858 - $4
    (10) jvc 16 pin wiring harness - $4 each
    (5) Sony 16 pin wiring harness - $4 each
    (1) Pioneer Wiring Harness - $4
    (1) Eclipse Turbo Timer Harness - $5
    Tsunami Basic 4 channel RCAs - $10
    Tsunami Premium 4 channel RCAs - $15
    Tsunami Premium 2 channel RCAs - $15
    Street Wires 2 channel RCAs used - $20
    Tsunami Ground Loop Isolator - $10
    Tsunami Ground Loop Isolator used - $7
    Alpine Faceplate Cover - $5
    Sony Faceplate Cover - $5
    JVC Faceplate Cover - $5
    Pioneer Faceplate Cover - $5
    (10) High to Low input RCA's. - $5
    A lot of MTX amps have a low or high input switch and you can use these to splice off the rear speaker.
    GCO Member
    NRA Member
    warner robins
    GCO Member
    NRA Member
    so it is a high to low rca converter? i am wanting one where u located it will take my highs and convert it to a low output hookup for my amp?
    warner robins
    GCO Member
    NRA Member
