Thread: vtec or non vtec
    Apr 2011
    Default vtec or non vtec
    Right now I have a y7 , should I go vtec like z6 or y8 or just build my y7 need some opinions.
    NA/Boost I got both. Supraboy87T's Avatar
    Jul 2009
    Are you staying all motor? If so what kind of power are you looking for? If you are aiming for high hp numbers with a D you need to boost. It ain't cheap to build a high hp D. If you are just going for bolt ons and a tune I don't think it'll matter which motor you build slow is slow. But I'm building an all motor Z6 if you look in this section further down.
    SOUTHERN SPEED
    macon ga
    Ive always been for vtec because of the gas mileage but scottie from mainstream seems to do good with his boosted non vtec .
    I dont think it realy matters with what your trying to do . Before to go through trying to find a vtec head and ecu to swap it all over buy a cheap turbo kit or save for a swap of some kind.
    252plus hp and 34.5 miles to the gallon all motor. 12.2 at 111
    Apr 2011
    H22 ?, what does vtec do for gas milliage? Are you saying go vtec head and ecu or just get a swap and boost it ?
    IA Member Toreyjw1's Avatar
    Quote Originally Posted by GlennsEK View Post
    vtec locks the intake and exhaust lobes together, changing the duration adn profile of the intake. thus delivering the stoich a/f mixture that your fuel maps give! essentially, say youre putting around pre vtec, at about 4 grand max, your not dropping nearly the amount of fuel as a if you were in vtec. if you were in vtec, yur revs are going to be two times as high, so two times the fuel consumption, not to mention the compensation of the higher intake as well. take into consideration, vtec engines lack drivability at low rpm severely. which is why a b20 engine will feel much more "torquie" due to their lower powerband, not necessarily due to thier displacement difference.
    race application or always driving fast, i say vtec. daily driver with some spirited driving here and there, non vtec.
    SOUTHERN SPEED
    macon ga
    Its just easier to run a big cam in a na set up and still keep drivability and gas mileage with vtec . If your going to turbo as long as you stay out of boost it works the same way .
    Long term goals is what we need to know to help you but since you did post this in the na section i would say go vtec . I wouldnt say go through the trouble to go sinlge vtec though . Its just to much trouble with no reward . Save up for a swap or turbo your single .
    Jul 2009
    ^This. Ask me how I know. LOL
    Apr 2011
    I'm going z6 boost
