Thread: help
    GWEETO31052
    LizeLLa
    Default help
    i changed my 94 accord to a five speed but it keeps on eating the passenger side axle whats the problem?
    SOUTHSIDE
    what do you mean by eating?
    South Side Georgia
    Quote Originally Posted by wrekonize View Post
    I think he means ripping the boot on the c.v axle
    resize pic
    South Side Georgia
    Check for anything that could loose.
    resize pic
    <--- RIP :,( psycho_freke's Avatar
    Locust Grove
    Quote Originally Posted by oteewg31052 View Post
    Doubt if it has anything to do with your five speed conversion. Like Gerardojdm said, check for anything loose.
    Put the car on a rack, or make sure it's really stable on a good set of stands and shakedown the suspension.
    Wiggle the wheel up and down and left to right (check each side obviously). If it wiggles, look at your suspension
    components to see where it's loose. Most of the time if you have up and down movement it's an upper/lower
    ball joint, and left to right is commonly a tie rod. Those aren't the only things to go bad though. Make sure you
    look at your LCAs good, too. I would be willing to bet you've got some suspension issues causing your problem. Just my
