Thread: Toyota MR2 Spyder: ticking/rattling coming from top end
    ホンダ・インテグラ allout13's Avatar
    Dec 2008
    Cartersville
    Default Toyota MR2 Spyder: ticking/rattling coming from top end
    I have a ticking/rattling coming from my motor. It isn't so bad when the motor is cold, but when it reaches full operating temp it become quite noticeable between 2500-3500 rpm. It only makes noice when accelerating or maintaining speed. When letting off of the throttle the noise goes away.
    Valve clearances have been checked and everything is in spec. Timing chain tensioner has been replaced. Serpentine belt was removed and sound was still there, so that rules out the serpentine belt tensioner or even possibly the water pump. OCV valve was cleaned. Anything else that can be checked?
    Projects
    Sounds like a spun bearing toyotas are bad about that
    Dec 2008
    Cartersville
    It's possible, but the sound is coming from the valvetrain. The symptoms aren't like a rod knock either. If it were a rod knock, the sound should go away when the car is accelerating and get loud when you let off of the gas. Mine is behaving opposite of this. I lose all ticking when letting off of the gas.
    Projects
    Still sounds just like the Yota truck i had it spun a bearing and was quiet as can be till accelerating or revving around 3k.
    Dec 2008
    i know what it is this is the sound all the 1zz makes befor they start to drink oil. time for a new motor soon.
    it can be from 2 things
    Pre cat fail
    or
    the rings gave out and oil concuption is about to start like a quart a mile when it gets bad
    Rod knock doesn't always go away when the cars accelerating, hell I have had cars only knock between x rpms and load on acceleration... just fyi. And they wouldn't knock at idle.
    Dec 2008
    Cartersville
    Quote Originally Posted by MR.2 View Post
    Pre cat fail
    or
    nope
    pre cat was gutted when I got the car. I put probably 5 or 6k miles on the motor like this and had no abnormal oil usage.
    fwiw it ended up being rod knock
    1 and 3 were spun
