Thread: h22 ecu questions
    Certified Gearhead TattooedFish's Avatar
    May 2011
    Barnesville GA
    Default h22 ecu questions
    I tried searching for my questions but couldn't find an answers. I need to know what ecu should I use for my h22a swap. Engine stamp on my h22 head says 91 (wasn't sure if that mattered. ) my civic is a 97 ex that was already swapped with the vtec e motor will I have to buy a h22 harness or will I just modify my d harness
    revolution big mac's Avatar
    modify the d series and use a obd2 to obd1 jumper harness
    and u can use a p13 or 28 is most common. or chippep ecu of some sort
    May 2011
    Barnesville GA
    Would I benefit from getting a chipped p28 what is te best to tune with that's good?
    you are ae to make a bit more power i fu tune. u can turn off o2 sensors and knock sensors and thingso that nature
    May 2011
    Barnesville GA
    Thanks guys
    let me know if u need swap parts. i have shift cables and shift assebly. and the swap axel youll need for pass side
