Results 1 to 11 of 11
Thread: BRAKE FLUID IS LEAKING SOMEWHERE!!
    GWINNETT IS GREAT!
    Default MYSTERIOUS BRAKE FLUID LEAK!!
    hope i got ur attention with the title
    ok so my 92 prelude si 2.3 has a leak somewhere in the braking system.
    all lines are good, brakes bled and double checked...but the mechanic has it pinned down in the abs unit somewhere
    so heres whats going on
    brakes stopping working..the pedal really has to be pressed down all the way to even slow down and the tire start skidding.
    so to my knowledge it comes down to the ABS module and the relay..
    the relay should be good cuz its not the accountable for the missing fluid.
    so even tho the mechanic also checked the brake booster and the master cylinder besides the brake lines,
    do you think it could be the ABS module?
    im confused and not looking forward to paying 300 bones for a new Module..
    someone, advice would be helpful
    GWINNETT IS GREAT!
    anyone?????
    the mechanic is pointing to the module and says the brake fluid is leaking out of there...and it looks dry and dirty as a bone...so idk what hesss talking about...
    plz HELP!!
    Stang Mod slostang's Avatar
    Southside
    Anywhere brake fluid is present its possible for it to leak.
    GWINNETT IS GREAT!
    idk what to do..
    GWINNETT IS GREAT!
    im thinking about replacing master cylidner, booster and module all together...
    brake overhaul
    GWINNETT IS GREAT!
    TAKE A LOOK AT THISS!!!!
    OK ON THE RIGHT SIDE OF THE FUSE BOX ON THE TOP LEFT HAND CORNER
    WHAT IS THAT NEXT TO THE FUSE BOX ON ITS RIGHT???
    BRAKE FLUID GOES THERE AND MY MECH SAID I NEED TO GET THAT REPLACEDD!!!
    **NOT MY CAR PIC**
    Scottish Scotsman's Avatar
    on the road to recovery
    check under the carpet on the drivers side by the pedals , sometimes the master will leak back in through the firewall , hence why you see no visible leaks
    GWINNETT IS GREAT!
    Quote Originally Posted by Scotsman View Post
    hmm...hope that explains the weak squishy brake pedal...
    thanks scotsman
    Southside
    Dont forget your wheel cylinders out back. Those are common leak points...
    GWINNETT IS GREAT!
    thanks slowstang
    my ludes got 250K mies....
    i just ordered a brake booster and a master cylinder...they should diagnose future problems and may knock out my current problem by ruling out master and slave cylinders
    i need to order tha part my mechanics pointed at
    its the thing on the right of the fuse box on the pic above i posted!! CHECK IT OUT!!
    lemmme know what it is!
    GWINNETT IS GREAT!
    omg...so i did research
    i have the infamous failing abs modulator...
    so i need one..
    i can go without it too..and save like over $150-300
    so to go with abs or to not to...thats the question..here ill post it n another thread
