Thread: 91 INTEGRA MAIN RELAY CLICKING HELP!!!!!!!!!!!!!!!!!!!11
    Default 91 INTEGRA MAIN RELAY CLICKING HELP!!!!!!!!!!!!!!!!!!!11
    hey guys i need some help im completly stumped..my car wouldnt crank up anymore i thought it might be the main fuel relay bc when the switch is in on position it clicks fast like a jack rabbit humping... i replace the relay and the same thing, and i checked the fuel pump and its good...i check all grounds and they are good..but what i did notice when i checked the dizzy my rotor button was really loose and the cap was chewed up...but in theory will that cause the relay to constantly click.........oh and by the way i forgot to mention i can put gas in the intake and itll run until it burns the gas in the intake......any suggestions please lmk thanks.................
    Dec 2008
    Northside
    check all ur fuses under the dash, i know one of them is linked to main relay and fuel pump. i wanna say its was fuse number 14 on my 91 EF
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    ok thanks..imma check all of them soon as i get home..........
    SOUTHSIDE
    100 percent sure that its the ground wire on the thermostat housing..
    i've ran into this problem before and thats your problem.......
    ive checked that ground alot and even wire brushed it and still clicky........ and all fuses are good too aswell..
    Rome,Ga
    Starter bad? Or ignition switch it will light up the dash lights in still be bad
    SOUTHSIDE
    okay check the ground from the battery it should have 2 one going to the tranny and one going to the frame
    the only reason the relay will click like that is because its not getting enough ground
    Quote Originally Posted by wrekonize View Post
    thank u guys sooooo much apparently it lost ground to the fuel pump itself as soon as i got it a good ground it fired right up.............YAY........thank u everyone for ur help....couldnt have done it without yall....
    when a relay clicks it means it's working, that sound is the relay opening up to allow circuit flow.
