Results 1 to 10 of 10
Thread: Cleaning a transmission
    I eat my boogers. 00Civic's Avatar
    Apr 2010
    Default Cleaning a transmission
    Hey guys, quick question about cleaning a transmission. I just picked up a transmission and I was wondering what are some of the different techniques that you use to clean it?
    Pressure washing it? Hosing it down with a garden hose?
    The transmission is sitting on the ground and I was wondering, would hosing it down with water harm the internal components of the transmission?
    Any tips/advice is appreciated!
    Try not to spray directly into the open differential holes, or speedo hole. However I use some cleaner and water to clean the trannys I rebuild, pressure washer makes it a lot easier.
    Scottish Scotsman's Avatar
    on the road to recovery
    purple power and a rag
    Stang Mod slostang's Avatar
    Southside
    Brake cleaner
    No go del slo Jdmsol's Avatar
    Nov 2009
    Bremen
    I use fine grit steel wool, and a brass wire brush
    JDM as......
    93 accord cb7
    (traded)
    93 del sol eg1 (traded)
    94 integra dc4 (sold)
    96 db7 ls-t (daily)
    Middle, Ga
    Purple Power and a tooth brush. Have it looking fresh after a hour. Did 3 engine bays and it works better than grease lighting to me. Plus, its cheap at mostly any parts store. Mix it with water if you ever plan on cleaning painted area's. Found that out the hard way.
    "Damn, Its Tyler"
    RaceReadyDevelopments
    Apr 2010
    Thanks for that info as well FasTech. I've been planning on cleaning my engine bay at some point next week
    I put rags in all openings, sprayed mine down with purple power, let it sit, pressure washer, then a lot of brake cleaner to get any left over loose dirt and to dry up any water.
    Northwest Georgia
    dont even bother with rags...a little water is NOT going to hurt a tranny. Pressure was the hell out of it and then DRAIN IT before putting fluids in it. If there is fluid in it already then leave it, pressure wash it, then drain it and the water will come out with the oil. The water really wont even get on anything except little spots of the diff, its just going to go strait to the bottom and the stacks are not at the bottom.
    Super Certified metalmatt47's Avatar
    Jun 2010
    Powder Springs, Georgia, United States
    Quote Originally Posted by 00Civic View Post
    Hosing it is probably a waste of time. Stuff it with rags and pressure wash the bitch.
    If you don't have one, go to the local car wash and spend a few bucks there. Take some purple power with you.
    Conformity is the jailer of freedom and the enemy of growth.
    - John F. Kennedy
