Results 1 to 10 of 10
Thread: Removing Stock Wrist pins..
    Privateer Racing!!
    Duluth,Ga
    Default Removing Stock Wrist pins..
    How do you do so on a GSR motor? No machine shop wants to touch it due to scared of craking the piston. How do you guys do it?
    You need a press and they only come out one way.. Call around, a good shop will do them for you!!
    Goza Auto Parts & MacHine Shop
    770-974-2088
    4391 S Main St
    Acworth, GA 30101
    Privateer Racing!!
    Duluth,Ga
    Has anyone tried to heat them Up? I read you can heat the rod up and the wrist pin will fall out, i could careless about the rods but im trying to save the pistons.
    Quote Originally Posted by B18c1Turboed View Post
    Yes that works but if you haven't done it then spend the 15 buks eack to have them done right!!
    Privateer Racing!!
    Duluth,Ga
    What machine shop will do it? Ive been to 4 and none would do it.
    I posted it above, but here:
    770-974-2088
    4391 S Main St
    Acworth, GA 30101
    its also kinda dangerous because if the pistons have been run (im assumung these are used) you jeopardize the integrity of the pistons by removing them. The wrist pins usually lock in place and the reason why most machine shops wont do it is because its too much of a liability. Once you remove the wrist pin it almost always cracks the piston, even a hairline fracture will cause problems later on once you reassemble it in a motor.
    Almost no reputable machine shop or machinist will reuse a cast piston. Its just asking for trouble. They are $100-150 new, id just buy another set
    But if you decide to do it anyway, just be warned it could fail. You can heat it up, but even that is asking for trouble. They are press fit, and designed to be used once.
    Privateer Racing!!
    Duluth,Ga
    ok thanks guys. All this stupid crap becasue i lost 3 rod caps...
    CORRECT!!!!
