Results 1 to 40 of 56
Thread: Fluctuating Idle Problem - 2000 Civic
    I eat my boogers. 00Civic's Avatar
    Apr 2010
    Default Fluctuating Idle Problem - 2000 Civic
    Hello guys.....it's that time when I need someone's help on here. First time too.
    Anyways, here's the 411. I just bought this car 2 nights ago for pretty cheap. It's a 2000 civic ex with a D15b7 motor in it.
    Two issues. Fluctuating idle and bad transmission. ( I'm not worried about the transmission ) - Buying a new one within the week.
    The idle issue is where I'm stuck at. It's going from about 1400rpm to 2000rpm back and forth. I came across a disconnected plug that was supposed to be in the IAVC, so thinking I fixed it, I plug it back in, no luck.
    I've never had to deal with an IAVC and was wondering if anyone can point me in the right direction? Thanks!
    Apr 2010
    What voltage reading should I get if I were to test it to the body ground with the key in the (int) on position? I want to make sure it's not an electrical issue.
    Dec 2008
    Northside
    are you sure that was the right plug that goes to it? its IACV by the way
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    Apr 2010
    There are two that can both connect to it, and I've tried both and no luck.
    Apr 2010
    I've just now sprayed it with a throttle body cleaner and in about 30 minutes, going to re-install it and see if it does the trick. I wanted to take this opportunity and volt-test it. I was wondering if anyone knew what the readings should be
    Apr 2010
    No luck. No difference at all. I'm going to check electrical before trying a new IACV. Where should I test for voltage? Any suggestions would be helpful.
    (ノಠ益ಠ)ノ smoknlegend's Avatar
    Around
    Remove and clean the iacv with cleaner then reinstall. Also check to make sure your cooling system is air free, air bubbles in there can cause idle fluctuations.
    Apr 2010
    Quote Originally Posted by smoknlegend View Post
    Already cleaned and reinstalled it. No difference. No air bubbles in coolant hose. I need to find someone around the Macon area with an IACV laying around to test it.
    barrow county
    1:iacv is not a plug, its a hose. if it was disconnected, you'll be shooting out anti-freeze/water.
    2: d15b7 is a obd1 motor. i hope its jumped to obd1 ecu and not obd2.
    3: like above, it hope its not on p2p ecu, obd2 d16y8 vtec ecu.
    4: idle like that is normally iacv, or a extreme vacuum leak
    i would check the obd conversion first.
    Apr 2010
    I just double checked with the ECU identification chart.
    Now I have a P2E(OBD II ) ecu that's for a 96+ Civic DX
    Now I guess I am on the hunt for a P06 ecu!
    Dec 2008
    Northside
    Hmm yea u sir are wrong. Iacv does have a plug going to it so the ecu can determine location and compensate for any adjustment needed. If he doesn't have power/ground to it, it would cause this issue. And for 00civic I will try and find what readings u should get at the plug
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    Dec 2008
    Northside
    How do u expect to go from obd2 ecu to obd1 without a jumper harness?
    Quote Originally Posted by 00Civic View Post
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    Apr 2010
    Quote Originally Posted by *EFilliated* View Post
    I am getting a jumper harness as well when I get the P06.
    Dec 2008
    Northside
    kewl try that
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    2000 civic EX, if you are using a EX engine harness then you have a bad IACV or vaccum leak. if it is not a EX engine harness, you will need to move ECU pin B6 to B23 and remove B15
    Apr 2010
    Wouldn't the P2E (obd 2 ) ecu be causing the fluctuating idle if I have a obd 1 manifold? The back of the intake manifold says P06 HF 5.
    Super Certified metalmatt47's Avatar
    Jun 2010
    Powder Springs, Georgia, United States
    Hold on now, I'm confused. it's a 2000 model, but it's OBD1? I'm no Honda guy, but this makes NO sense to me. Maybe I'm wrong, but I'm pretty sure any car '95 1/2 and up were all OBD2, with some exceptions on '95/96 models.
    Sounds to me more like a vacuum leak then anything. Either that or something is routed incorrectly.
    Conformity is the jailer of freedom and the enemy of growth.
    - John F. Kennedy
    Apr 2010
    LOL, yes it's a 2000 model but the 92-95 civic motor is in it. Don't ask me. I bought it this way and couldn't pass up a good deal.
    Apr 2010
    Is this in reference to a P2E ecu or an EX ECU?
    Jun 2010
    Ahhh that makes sense then. Not sure why someone would go backwards on an engine swap though :P
    - John F. Kennedy
    Dec 2008
    Northside
    HONDA owners
    Quote Originally Posted by metalmatt47 View Post
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    Apr 2010
    You're telling me.
    you need a p2p OBD2 ecu, or a Jumper harness & OBD1 ecu. p2e is a Y7/3 wire IACV ecu.
    Apr 2010
    RBS, you have aim or yahoo? real time messaging would be easier
    Apr 2010
    Apr 2010
    RBS, someone already repinned the B plug. Exactly the way you said to do. So, do I need a new IACV or a P06 Obd 1 ecu?
    IA Member candycoated's Avatar
    Sep 2010
    canton, ga
    mine had the same problem, it was my coolant.
    Apr 2010
    I'm going to try a new IACV on there to see if it solves the problem. If not, then I will go from there.
    Sep 2010
    canton, ga
    goodluck!
    try another ECU before anything else, you need a p2p (Civic EX Vtec) or a OBD1 computer.. any OBD1 will do
    Apr 2010
    even OBD 1 automatic ecu's?
    Dec 2008
    Northside
    no it has to be 5speed
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    Apr 2010
    That's what I thought, but he's the one who said " any obd1's would do ".
    So anything that's obd 1 and 5 speed would work? are preludes, accords excluded from this?
    Dec 2008
    Northside
    i dont know about prelude/accord ecu. get a p28 or p06 5 speed. have u checked for vacuum leaks?
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    when i said any OBD1 ecu, yes i meant any OBD1 honda/acura ecu.... most automatic ecus will make the car DRIVE funny, but this is about the idle
    Mr.CL Feriozfinest's Avatar
    GWINNETT
    All u gotta do is clean the IVAC. They have video's on Youtube that show how to to do it step by step.
    GWINNETT
    I had the same problem. Do waste ya money on a new IACV.
    Apr 2010
    So, here's my understanding / breakdown of what I've observed so far. I have a 2 wired IACV.
    (92-95 civic DX motor ) used for 2-wired IACV's
    (P2E ecu (96+ Civic DX ) for 3-wired IACV's - but there is not an orange wire ( which is used for the 3rd wire in the IACV )
    (99-00 Civic EX harness ) used for 2-wired IACV's - No orange wire
    At this point, it's looking like I might need to get a P06 ecu so that it won't look for the 3rd ( orange ) wire.
    Here is the thing. The wiring harness that's under my hood is OBD2, would it be stupid to get an OBD1 ecu, or is there a way to keep this P2E ecu and solve this issue? Any suggestions/advice is welcomed.
    Apr 2010
    ORRR
    Should I just get the P2P ecu so that it doesn't look for the 3rd wire?
    Apr 2010
    Anyone who can solve this issue will get $50. No joke. If your idea/suggestion works and fixes the problem, I will be more than glad to pay the $50 =).
