Results 1 to 3 of 3
Thread: FS: Rotora Big Brake Kit
    Shine on! Nittanys1's Avatar
    Raleigh, NC
    Default FS: Rotora Big Brake Kit
    For Sale
    RETAIL:
    Honda Accord 1998 - 2002 RBK003.01 $1425.79
    Trim: V6, 4CYL Specs: Front Rotora Brake Kit - 4-PISTON - 330x23 - 1 Piece Rotor - 17'' wheels required
    MY PRICE $1000 plus shipping
    THIS FITS BOTH 4 and 5 lugs
    Fits:
    Acura CL 3.2L V6 2001-2003
    Acura MDX 2001-2005
    Acura TL All 1999-2003
    Honda Accord V6, 4CYL 1998-2002
    Honda Odyssey 1999-2004
    Honda Pilot 2003-2004
    Product Information
    Rotora Fr. 1pc 11.6in Brake Kit 4pot Honda Accord Wagon 98-02
    Made of billet aluminum alloy and CNC machined to ensure the highest quality; Rotora's high performance brake system enables superior brake modulation while improving overall pedal feel to ensure equal distribution of weight transfer when braking. To achieve this proportional front-to-rear brake bias, Rotora’s opposing piston calipers are fine tuned by increasing the clamp load to the optimal level while utilizing the stock master cylinder to retain overall front-to-rear brake bias. Rotora’s full big brake system design delivers excellent initial bite, exceptional modulation, and consistent pedal feel for street and track use applications. All systems are ABS compatible and direct bolt on replacement with minimal modifications required.
    Features:
    -Rotora billet aluminum alloy 4piston racing calipers with sequentially sized piston bore sizes engineered to each specific vehicle.
    -Rotora billet aluminum hat with "floating" disc assembly to reduce heat related stress and unsprung weight.
    -Rotora 1 piece vented heat treated directional vane disc system to improve airflow/cooling under severe braking. Slotted or drilled & slotted oversize discs (295x23mm) to ensure equal heat dissipation and increase thermal capacity while relieving the disc and brake pad surface free of excess debris.
    -Rotora ceramic formulated pads designed for extreme street and track application with high co-efficient of friction and high temperature fade resistance.
    -Rotora DOT compliant stainless steel braided brake lines to improve stiffer pedal feel and prevent brake hose expansion.
    -Rotora carbon steel (SC45) mounting brackets (depending on application) and hardware.
    Options:
    Color: Red or Metallic Blue
    Rotor: Slotted or Drilled & Slotted
    Please select color and rotor options below.
    Fits: Honda Accord Wagon (Japan Model) 98-02
    Click for more videos
    Click Arrows Below for More Videos
    About Manufacturer: Rotora
    Founded in the fall of 1999, U.S.-based Rotora is a major aftermarket manufacturer of high performance brake systems and components including racing calipers, brake discs, and pads ranging from Original Equipment aftermarket replacement parts to racing and high performance upgrades.
    Through rigorous research, design, engineering, along with extensive road and track testing to produce the most innovative brake systems available on and off road, Rotora’s high-quality and specifications are maintained through strict quality control inspection, which assures that every component meet worldwide ISO 9000 quality standards.
    Extras:
    If you purchase the BBK and these items below I will discount the total.
    Rotora 13" Rotors (new, never used): http://www.importatlanta.com/forums/...8#post39246988
    Rotora Brake Pads (new, never used): http://www.importatlanta.com/forums/...7#post39246987
    oh man, if i only had the money....
    Raleigh, NC
    PM me an offer!
