Thread: build ls/vtec turned on and then shut off. (HELP PLEASE)
    The Fuck allmotor-teg's Avatar
    Dec 2010
    down in georgia
    Exclamation build ls/vtec turned on and then shut off. (HELP PLEASE)
    my ls/vtec motor just got build(HAD 87 OCT IN THE TANK, maybe thats the cause but idk) have all the plugs wires, dizzy, ecu and everything but last night when i went to start it for the first time it will not doit with just the key ignicion, had to use a tool to touch both of the wires in the starter, the car turned on fairly quickly, no weird noises nothing it was on for like 2 mins and it died, we tried to turn it on but it wont turn on, tried 3 cylenders and it worked but not with all 4, the fourth was producing spark but cant identify whats the cause of it not turning on, idk if its the gas, the ecu i really have no clue whats going on, the injectors were working fine, dizzy works, brand new spark plugs, what you you guys think???
    sorry for the long reading.
    thanks in advance (ricardo)
    Hold On Not Done Accelerating
    Rome,Ga
    Ground may- b came lose should have 3 grounds
    Ecu fuse may have blown
    Main relay
    Ignition switch
    Rome,Ga
    Also icm in dizzy could make it misfire
    Quote Originally Posted by allmotor-teg View Post
    Ok first of all if you mean you put the key in, turn it, and NOTHING Happens, either your starter is bad, you have a bad ground, or your battery is dead. Diagnose that first. Battery should have proper voltage, try jumping it off, check all your grounds, hit starter with hammer, etc.
    Gas isnt a problem unless its more than 6 months old. Ok so it cranked up ran on 3 cylinders then shut off. Well if its a fresh built motor its not uncommon for a cylinder to be "dead" until the rings seat. Which should be instantly so you have some work to do
    1) Determine if its a fuel or spark issue. You said the cylinder had fire. So its either a dead cylinder or a fuel issue. DO A COMPRESSION TEST and see if that cylinder is low. If it is not, then make sure the injector is firing and has power.
    What injectors are you running? What ECU?
    Do all that and report back on what you find
    Dec 2010
    down in georgia
    [QUOTE=terrytowe22;39245558]Ground may- b came lose should have 3 grounds
    Main relay
    Ignition switch[/QUOTE
    does 87 oct fuel compared to 93 oct make such a difference that it will not run??
    Dec 2010
    down in georgia
    thanks vtec kidd
    1)i would to that compression test asap.
    2)stock injectors, using a stock p28 ecu
    3)ill get on that.
