Thread: D16Y8 Bogging Down Under Full Throttle
    IA Member ATLchris's Avatar
    Flowery Branch
    Default D16Y8 Bogging Down Under Full Throttle
    Haven't done much yet, cleaned the throttle body, IACV, replaced the fuel filter, a bad plug wire, and put a new thermostat in.
    When at idle, if you go full throttle, it bogs out and stalls the motor.
    If you ease the throttle and feed it up to 1500 RPMS it will rev up fine without stalling out.
    Just when you are at idle and give it full throttle, it will stall out.
    I can still drive it, just have to ease the throttle.
    But I really want to get this fixed! Help?
    Video Below.
    http://s280.photobucket.com/albums/k...4-18-37-45.mp4
    BB6 Prelude Srt's Avatar
    Oct 2009
    Hall County
    and now the car wont start at all! (distributor/fuel pump?)
    Dec 2008
    Northside
    i would check ur tps and make sure its good
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    Oct 2009
    Hall County
    Well I had told him that today, and he went down the road and the car died completely. Rotates, but wont crank.
    Dec 2008
    Northside
    From personal experience I have had my sohc ef just die on me while driving and it turned out it had jumped timing, dizzy must of moved or something from missing bolts. Center the distributor and make sure its bolted down properly, if that doesn't fix it try and find another dizzy. Make sure ur getting fuel also/primes
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    Certified Gearhead YoItsCarlie's Avatar
    Mar 2011
    Cel Codes are your friend.
    check for spark, check for fuel. chekc distributor internals. check TDC.
