Results 1 to 2 of 2
Thread: Electric gurus how to diagnose and fix electrical problems
    ZOMG ChnkyLao's Avatar
    Winder, GA
    Default Electric gurus how to diagnose and fix electrical problems
    Alright my car has been down for about 2 weeks now because it keeps blowing a fuse. I would love to learn how to track down and fix this issue so any advice on diagnosing this and fixing it would be helpful.
    Quote Originally Posted by quick timieline of car issues and fixes since i had it
    About 4 months ago I had hopped a curb and broken all kinds of things on the bottom of my sc link to the thread
    I ended up buying a parts car and replacing the parts myself using jacks, an engine brace, and hand tools. Got the up and running successfully for a couple of weeks. Then I had an ignition interlock installed on it
    Then a week after the ignition interlock was installed, the damn thing stopped working on me and I couldnt start my car for two days. Got another one and a day later I blew an efi fuse link to url
    that problem was temporarily fixed by removing my foglights
    Now the problem came back link to thread
    This time the engine cut off when I floored it. The problem of the efi fuse still remains.
    - the car -
    1995 sc400
    mileage 300k+
    - mods to the car -
    hid low beams,
    coilovers
    wheels,
    led taillight bulbs
    - the issue -
    keeps blowing the efi (electric fuel injection) fuse as soon as i turn my key on
    the fuse is a 30amp fuse so i can't just put a bigger one
    starter is clicking,
    there is still spark,
    no fuel is getting to the engine because this fuse is blowing
    - tried failed fixes -
    clean the battery terminals
    Regrounded the ground wire that was connected to the battery terminal that i forgot to connect
    checked and reouted the wiring harness that was under my driver wheel well
    bypassed the fuel pump ecu incase my fuel pump ecu was going out
    swapped out my fuel pump with the fuel pump from my parts car
    Stang Mod slostang's Avatar
    Southside
    Sounds like you have a dead short in the wiring somewhere. Only real way to fix it is to get a wiring diagram, look for EFI stuff that receives power from the ignition and trace wires.
