Results 1 to 18 of 18
Thread: EG with F22B1 wont start; Please Help
    Certified Gearhead CraigMW's Avatar
    Carrollton, GA
    Default EG with F22B1 wont start; Please Help
    Whats up everyone! I hope i am posting in the right section, if not let meknow and i will be happy to post in the right section. Last year I purchased a 1994 Honda Civic Hatchback with a freshly rebuilt F22B1 SOHC Vtec engine with around 9000 miles on it. All work was done by the previous ower. The car ran really good and really strong at first but all of a sudden, more and more problems started to occur with the car. First, the transmission started messing up on me and i am no longer able to shift in 1st, 3rd, or 5th gear... well, thats not that big of a deal, i can handle that because i dont drive the car that often plus i am pretty sure it is just the shift linkage... well, after about 2 weeks of that, one morning i go to start the car and it will not start at all, it tries to turn over but it is very weak and sluggish. Does anyone have any suggestions for me? Any help at all is greatly appreciated. I have checked the battery and changed the spark plugs and that did not help at all. Thanks for looking. (I have taken a video with my phone of what the car is doing when i try to start it and will e-mai it to anyone who wants to take a look at it for troubleshooting.)
    F22 powered 94 Civic hatchback!
    03 GSX-R 1000....SOLD!!
    00 Civic Si......SOLD!!
    Senior Citizen Dylan's Avatar
    Milledgeville
    Is this hatch ur talking about blue?
    Carrollton, GA
    yes it is.
    Milledgeville
    Ok im pretty sure that is my old one then.I had a few random problems out of it but never cranking issues.does it still have the wire tuck?
    Carrollton, GA
    yea. is this Mike? yes, it still has wire tuck.
    Carrollton, GA
    what are some issues you had with it?
    Milledgeville
    No its not mike. I had some minor problems with it going out of tune and some of the wiring.
    Carrollton, GA
    oh ok i got you. The guy i got the car from his name was Mike, he said that he did all the work... but o well. ill get it running.
    athens
    three first things to alsways check for first
    spark, fuel and compression.
    Carrollton, GA
    I think i have it narrowed down to being my starter. It will not turn over fast enough to tell if i have spark. i know i have fuel, pressure guage reads 40. Would i have to have the car running to check the compression? Thank you for your input Chip P. i appreciate it.
    athens
    the car doesnt need to be running but it would need to be able to turn over. unless you wouldnt mind turning it over by hand which would no doubt take much longer. i know you said you checked the bettery but do you have a voltmeter to read how much jiuce is in it? newer batteries should read like 12.4 so it youre far under that you know its the battery. and if youget it running do the same test but for the alternator, while the car is running it should read around 14.6 if not its the alternator.
    take the battery to an autosone or advanced auto and have them chek it out maybe theyll be able to recharge it. then try that along with using the vold meter for the forementiond test on alternator. also maybe check the battery ground to the car and battery positive to the starter, clean and tighten the connections to both
    Carrollton, GA
    Thank you for the info Chip. I am going to check the starter and go from there. i am hoping that is all it is. i know this is prob a stupid question but... Would you happen to know the location of the starter?
    athens
    well its more than likely on the left side of the motor(standing in fron of the car) on top of the transmission. if you follow the positive cab;e from the battery down it will end up on the starter. it should have a cylinder shape.
    Carrollton, GA
    Thanks man. I pulled my starter today and did the "Bench test" where you hook up the jumper cables... the shaft comes out but does not spin at all. I went ahead and ordered a new starter. Hopefully this will get it running!
    athens
    woo! no problem man
    . hope that fixes it.
    Carrollton, GA
    me too man. I miss driving it. I will keep you posted since you are the only one so far with any kind of input.
    Carrollton, GA
    Ok... I have replaced my starter and it started right up. I drove it a while and parked it... I go to start it back up and it does the same thing again... and now it will not start back up without being pushed off... any suggestions? Think maybe i have something that is shorting my starter out? Please help! Thanks so Much!
    Carrollton, GA
    Also, since i replaced the starter and while driving it before it quit starting again... the radio and clock is no longer working and it is not due to a blown fuse. I cannot jump the car off, nor can i jump the starter but i can push the car off and get it to start that way...
