Thread: automatic gsr issue
    in a paint booth
    Default automatic gsr issue
    ok i got a big cluster f*ck going on but im determined to get this running right.
    ok first i have a gsr block with a automatic tranny in my 99 crv which is obd2b.
    first i wanna know if there is a automatic computer i can run that will let me rev out and engage vtec.
    second if there is not then any ideas on what i can do and how can i get vtec to engage.
    please no b*llshit this is a seriouse question and im getting really frustrated and wanna know if anyone else has any ideas.
    statesboro
    I know in japan,they had an auto gsr,might try tracking down one of those ecu's. I have no other info on this topic,best of luck to you.
    del sol? 94_teg_ls's Avatar
    summit has a rpm switch. you can use for vtec
    /sig
    Back from R&D Land
    Back from R&D Land
    Yes, there is an automatic GSR ecu that you can use. I have two of them in stock, they are both OBD1 four plug ecus. What trans are you using? I build ecu jumper harnesses that convert from OBD2/1/0 to run the automatic ecus. Let me know if you are interested.
    JK
    www.JKOBD.com
    00 Civic Street Car V2 coming soon
    in a paint booth
    Quote Originally Posted by 94_teg_ls View Post
    yea i tried that piece of crap it kept cutting in and out and i ripped it back out and threw it at a wall
    damn sounds fun though. which ecu are you using
    /sig
    in a paint booth
    right now im using the stock b20 for now until i get my stepdown and get my tuner to tune it
