Results 1 to 4 of 4
Thread: H22a del sol help please
    Rome,Ga
    Default H22a del sol help please
    1.oil leaks between head in block? Head gasket?
    2.when it was running the motor would idle but did not wanna rev till I got to higher rpm?
    to answer both questions at the same time. your head gasket is blown and you are loosing oil pressure so your vtech is not work. replace headgasket and us arp headstuds.
    About to approach beast mode
    Or re torque them and see if it goes away .... I seen so many people that does head work and don't know what the specs are and under tighten them ...
    If torque is correct either bad gasket or ,gasket on wrong....
    Rome,Ga
    Thanks for the help figure out the part store gave as f22 head gasket installed the new one it doesn't leak at all reps will be giving
