Results 1 to 15 of 15
Thread: metal on metal squeal
    statesboro
    Default metal on metal squeal
    I have an integra and there is a noise coming from my from left fender well. Started happening awhile ago and is getting worse by the day. It happens on and off when im driving,the only way it goes away is if i slam on the and then comes right back. I was told by a few people it could be the hub bearing,so i replaced that along with the brake padsand rotors. Im all out of ideas on what it could be.
    Newnan
    is it a scrubbing or a scraping? is it only during braking?
    learn to english
    statesboro
    Quote Originally Posted by Humphries View Post
    Happens during normal driving,and idk,its metal rubbing against metal for sure.
    Newnan
    wheel bearing.
    replace it.
    learn to english
    statesboro
    wheel bearing.
    replace it.
    already have
    Newnan
    welp.. thats all i've got.
    learn to english
    Dahlonega
    brake backing plate bent and rubbing on the rotor?
    statesboro
    Quote Originally Posted by Cynical 1 View Post
    Ive check that already and there was a little distortion on the very bottom,i might think for some reason it is not rubbing on the rotor when the car is jacked but is when its on the ground,if i cant figure it out soon i might remove it.
    Newnan
    just bend it.. it's thin metal.
    learn to english
    statesboro
    already tried that,didnt really work
    cut it off
    athens
    how did the old rotor look? id look more at the caliper than anything else now that youve checked the other stuff out. make sure its not cracked or chipped or damaged in any way also clean of debris. it couldd also be that you have a sticky caliper. when youre driving or under braking does the car drift to the left? yo may just need to grease it up.
    one more thing beofre all that...id check to see that you havent overfilled the brake fluid res.
    05srt4
    Jun 2009
    Upatoi, Georgia, United States
    yea i was gonna say the dust shield hittin the rotor but i guess u already tried bending it
    PROBLEM WAS FIXED!!
    statesboro
    Quote Originally Posted by Tech5 View Post
    PROBLEM WAS FIXED!!
    ? Do I know you? it hasn't made it for quite a few days so I guess it went away temporaryally. Hadn't had time to check out anything out recently.
    Sent from my iPhone using Tapatalk
