Results 1 to 1 of 1
Thread: T/W: 1989 civic hatch project: {part out}
    Senior Member rbf's Avatar
    Sep 2008
    Augusta
    Default T/W: 1989 civic hatch project: {part out}
    My current project must go. It currently is not running due to ignition issues (distributor/ecu?) and the transmission is long overdue of replacing. The trans will allow you to drive but not sure exactly how far you would get. Before it went in for paint the trans started acting up grinding only sometimes in random gears and was making fairly loud clunking noises at idle. I've put alot of time and money into the vehicle and just do not have the time to put into it w/everything going on.
    Please keep things on topic and if there is nothing positive to say then please keep to yourself
    . Thanks.
    Year: 1989
    Make: Civic
    Model: Dx 5spd
    Motor: d15b7 (block code = 2306390 )
    Miles: See photo
    VIN: 2HGED6355K*******
    Shell: $800 + depending on what you want it to come with.
    Engine: $400 + depending on what you want it to come with.
    Please do not ask if I will part w/a single small item because the answer is no. I am willing to sell the car complete, just p/m me if interested thanks.
    MODS: {bay}
    fresh LBBP painted engine bay, 3 coats of clear. (sprayed 4/8/2011)
    full chassis and engine wire tuck
    Downstar/bolt boys spike nuts
    stainless steel washers w/allen head bolts throughout the entire engine bay
    fresh powder coated valve cover w/vc gasket (wrinkle black)
    custom fully polished fuel rail, injectors and fuel pressure regulator
    custom made aluminum air intake also fully polished
    brand new aluminum dual core racing radiator w/slim fans (installed 4/8/2011)
    new distributor 0-ring from honda. (installed 4/11/2011)
    New injector 0-rings
    brand new EXEDY clutch/pressure plate. (not installed)
    New cv axles (installed 4/12/2011)
    MODS: {interior/exterior}
    90-91 civic steering wheel
    integra seats
    blox shift knob
    clear corners
    clear bumper lights
    adjustable coilovers
    dc header
    greddy 2.5" exhaust
    civic hx wheels
    88-89 civic si lip
    shaved rear key hole and antenna.
    Tons more.
    Bay before:
    Bay as it is today:
    vc not installed:
    The clutch:
