Results 1 to 10 of 10
Thread: H22 delsol swap
    Rome,Ga
    Default H22 delsol swap
    I'm gettin spark but I'm not for sure about fuel do u have to have a resistor box for
    Injectors?
    If your using the stock H22 injectors YES
    I would double check to make sure the resistance on the injectors is 2 or 12 ohm. Then go from there, it would probably run w/o the resitor box if you need it however it would be shitty.
    revolution big mac's Avatar
    i have a h22 eg and i would say go with resistor box. let me know if you need swap parts
    Rome,Ga
    The motor has yellow top injectors? Big Mac need to come help get this thing going
    Rome,Ga
    I installed a da resistor box it's getting fuel now we fired it up but we notice oil leaking between head in block on drives side? In the process of new head gasket but when it was running the motor did not wanna rev any info would help
    I would recheck the torque on the head bolts before changing the gasket ..... What ECU are you using??
    Rome,Ga
    Chipped p28 i torque the head to 29 then 51 then 72 in the order would the head gasket make it leak
    That might be the problem is the P28 mapped for H22?
    Rome,Ga
    The guy said it was not for sure though but I have several ecu let me try one of them
