Results 1 to 19 of 19
Thread: civic drinks gas like a big boy truck
    May 2010
    South Side
    Default civic drinks gas like a big boy truck
    buddy of mine his 97 civic ex(d16y8) is getting mpg's like a truck anyone know why?
    Dec 2008
    Northside
    there is tons of reasons y it might be
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    Quote Originally Posted by uho View Post
    you win info of the year award. it could be anything. does he have any engine lights? how does he drive? does he take care of it? when was the last tune up? see where im going? give us some info and maybe we can help you out.
    Earth
    Based on your detailed description it sounds like the #2 and #3 injectors are stuck wide open, your friend probably has not noticed the problem (other than the gas mileage) because he drives with the VTEC engaged full-time.
    May 2010
    South Side
    ha my bad guys lemme find out some more info see if i can get some better details, i do know his check engine light is on(i think he said he knows why its on) lemme find out whats up though
    timing
    tune up
    O2 sensor
    And performance add ons
    some installed 660cc injectors on a stock motor lol
    May 2010
    South Side
    okay so he said the reason his check engine light is on is bc of the idol control valve. so would that have anything to do with his gas?
    Stang Mod slostang's Avatar
    Southside
    Yes. If its stuck open it could be dumping excess fuel to compensate for the IAC fault.
    May 2010
    South Side
    ^ okay thanks man, i told him that he should try fixing that first. so i'll tell him he needs to fix it and see if that fixes the problem
    aye bro .:Stirfry:.'s Avatar
    yea like the other guys said could be several things. basic tune up. o2 sensor readings, fuel trim readings, tires, wheel bearings, CELs, the way he drives. what kinda mods. etc.
    ATL DAsquad Member #9
    Unless it's idling up and down due to the CEL for the IACV that code will not cause it to burn more gas . So if it's idling fine then ,don't worry about that code just yet . Check other problems that has an effect on GAS being wasted .
    athens
    any news on the mpg problem?
    it could be hes got a leak somewhere even beofre fuel gets to the injectors. has he checked for it? you could get a fuel pressure gauge and just stare at it for awhile.
    if thats not the case and hes dumping tons of gas into the cylinder you would def be able to tell. black smoke would be coming out and youd be able to smell it, not to mention a loss of power from running that rich.
    May 2010
    South Side
    well he has no leaks. were guessing it's the idle control valve for now bc that is what is making his engine light come on so whenever he decides to fix it hopefully that's the problem
    athens
    ive replace the IACV in both my integras and i never saw a CEL. im not if that will even cause a cel. the 2 things i know for sure that will though are the o2 sensor being disconnected/bad connection and main relay malfuntion. and i doubt its the main relay because youre able to start the car. its more likely the o2 sensor, if its got a faulty connection then its probably causing your car to stay in an open loop air/fuel mix. which is more rich if you didnt know.
    Duluth, GA
    Quote Originally Posted by chip P. View Post
    It definitely will cause a code.
    I am running my Integra with both o2 sensors missing right now, and I'm still averaging 30 mpg.
    athens
    Well i guess im remembering wrong. as for the o2 sensor, just throwing stuff out there that hadnt been suggested yet.
    Well its one thing offering advice if you know it's the problem or some what could be the problem . Logically speaking your advice failed to be the truth ....AS I STATED A IACV WILL NOT MAKE IT BURN MORE GAS UNLESS THE ENGINE IS REEVING UP AND DOWN... IF IT'S IDLING NORMAL AND JUST A CODE IT WILL STILL GET GREAT MPG .
    athens
    you feel like my saying the o2 sensor was not a good suggestion? i wasnt throwing out things just to be in the thread. i just felt like an o2 would be worth checking to help solve his problem.
    i dont disagree with what you said about the IACV burn more gas
    WELL he didn't say he had a CEL on because of a O2 Sensor
