Results 1 to 23 of 23
Thread: anyone know whats wrong here?
    unknown
    Default anyone know whats wrong here?
    i've changed the wheel bearing, changed the caliper, new axle. the only thing i haven't done is change the brake pads, or the rotors.
    Can it be that the rotor is warp or can it be the i need a new spindles cause the spindle is bent? i hit a curb pretty hard too a few months ago and now it finally act weird on me after i've change the wheel bearing.
    any help will help me alot. thanks i.a.
    http://img62.imageshack.us/i/vyy.mp4/
    bad rotor
    Dec 2009
    lawrenceville
    Just change the spindle its going to save u.time
    Dec 2009
    lawrenceville
    dam rotor its bend
    I don't think the rotor would be bent from him hitting something with the wheel on ....It's hard to tell in the pic but is the rotor butted up flush I was looking at the wheel studs to see if it was but your VID is hard to tell ...
    You could have the wheel bearing not in correct or the hub in crooked also ... I would re check your work and see before I change random parts.
    winder
    Quote Originally Posted by Tech5 View Post
    i would listin to what tech5 says.. he helped me with my brake problem an i didnt even have a pic or anything.. an he knew what is was.. thanks agian tech5
    Yo face! SUBY_RUE's Avatar
    in the land of ozz
    The hub seems to be bent to me... just make sure the bearing is pressed in right as well.
    For one hell of a life
    I got my girl got my family
    For a hell of a time
    HELLYEAH!
    Senior Member | IA Veteran Mad Mike's Avatar
    Gainesville
    Make sure the matting surface for the back of the rotor is clean and free of rust. If thats good pick up a rotor there pretty cheap. Can't really tell a lot from the video but the bearing nut doesn't look to be wobbling. If the spindle was bent it wouldn't wobble it would stay at a set angle.
    Good luck
    barrow county
    control arm
    unknown
    i think you might be right cause i change the rotor from the other side on and it still does the same thing. plus the prev. owner of the car changed it to integra brake front and back. so i didn't know and being stupid i went and got a civic wheel bearing for it and had the shop put it on. Is it cause of the wrong wheel bearing that is causing the wobbling?
    winder
    ow damn.. told you tech5 knows his shit man
    unknown
    Quote Originally Posted by ludeguy420 View Post
    so it's the wheel bearing then huh?
    winder
    to tell you the truth man i have no clue i would try an change it to the teg wheel bearing an see what happins.. i try not to fuck with shit like that..
    unknown
    cool thanks man
    winder
    i posted something about my brakes an said they where making a weird sound an he told me exactly what it was an i didnt even have time to post a pic an he knew what it was
    aye bro .:Stirfry:.'s Avatar
    the rotor would crack or break not "bend". but take the rotor back off and spin it from there and see if the hub is bent. which is probably what it would be. and a wheel bearing can only go in one way.
    ATL DAsquad Member #9
    unknown
    Quote Originally Posted by .:Stirfry:. View Post
    is there a different between civic and integra wheel bearing?
    Same
    Anytime man!!!
    I try to help when I can
    unknown
    ok i went and look up the wheel bearing for civic and integra and they both seems to be the same. they are same sizes and stuff like that. so can it really be the bearing then? don't really wanna waste the money to do it if it uses the same bearing
    Gainesville
    Quote Originally Posted by Eg4LiFe View Post
    I looked up the wheel bearings at autozone.com and they are the same. Part # 510030.
    Ether the disk isn't sitting flat on the matting surface or the bearings are not sitting right. Or it could be a really warped rotor.
    yea bearing is the same. take the hub off and inspect it and go from there. but once you do that your going to have to get a new bearing anyways bc 100% of the time the race from the bearing needs to be cut off or heated off one you take it apart. so you cant reuse the bearing and need to get a new one. and while its off take a look at the hub and rotor and see for any visual defects. like put the rotor on a flat surface. and its pretty much self explanatory the rotor sit on the hub. and since its a civic the rotor should have two bolts that bolt on to the hub. and as you can see in the video it wobbles.
    unknown
    thanks guys. i i've slove the problem already... and most of you guys are right it is the bearing that is mess up/ put in incorrectly
