Results 1 to 13 of 13
Thread: Brakes???
    winder
    Default Brakes???
    ok i changed my caliper the other day now when i push the brakes it is making a scrapping noise.. so i took it off an did it agian an its still making he same scrapping noise. i have checked the dust plate so idk what it is i need help ia
    Stang Mod slostang's Avatar
    Southside
    If your pads have a little piece of metal on either end remove it.
    winder
    those little brass pieces?
    Southside
    yep
    winder
    thanks im going to try that when i get off
    Those are WARNING indicators don't take those off , that tells you , you need to change your pads soon . What pads did you use and do they have the shims on the back??
    If it only does it when you press the pedal it's either the shim on the back of the pad or pad holders that are in the caliper bracket in wrong or it's a little to far to the rotor .ALWAYS grease the end of the pad the metal part that rest in those caliper holders this will prevent weird noises and makes the pad move freely... Also always lube the caliper pins
    winder
    Quote Originally Posted by Tech5 View Post
    they where just stock pads you but from advanced.. i replaced the pads less than 2 months ago.. i put grease on the pins.. i will have to check the shims in the morning.... it sounds like a piece of metal or something is rubbing but i dont see any scratches or anything on the rotor.. this is why i hate brakes
    Certified Gearhead jfryer496's Avatar
    Feb 2010
    Phenix City, alabama
    double check ur dust guards push them away from everything...
    Feb 2010
    ur pads Might be crystalized... depends on how hard you use them and what level pads u got
    Quote Originally Posted by jfryer496 View Post
    I have used the cheapest pads you could image and never had a metal to metal sound .maybe a squeak sound here there .
    Southside
    I had a issue with pad indicators with aftermarket wheels. also seen it happen with a few cars at work with aftermarket wheels.
    Quote Originally Posted by slostang View Post
    Sounds to me someone bent them , they are designed to only touch the rotor once pads has been worn down. It points to the rotor I don't see how this could make a noise unless they had bad (worn) down pads . I have replaced about 1 millions cars pads and never had indicator be an issue unless pads was worn or someone bent them .
    MaD Tyte y0! ek forever's Avatar
    carrollton
    Ditto on checking your brake dust guard thing. Mine occasionally bends over just enough to make contact at low rpms for some reason. Very annoying. Just bang it out of the way with a hammer or something.
