this has gone way past ridiculous, motor is out of the car i've heated this bolt, tapped it with a hammer heated it again tried the same method, used an air wrench. stubborn damn bolt someone tell me they have an idea.![]()
Try spraying it with PB blaster or WD40 (soak it) then hit it with a higher torque impact gun.
Work in progressneed slicks!
its soaked now just sitting in the garage gave up for tonight haha. guess ill borrow another impact gun tomorrow i only have the one. i've never had good luck with these bolts.
if it has a flywheel on it, thread a bolt into one of the threads and place another bolt to jam it. have a buddy hold the motor and use a longgggg pipe with 1/2 socket to break it
Bet my impact will take her out' haven't met a bolt she didnt remove![]()
yeah i figure my impact just wont cut it i purchased a big ass pipe today and thanks for the tip on jamming it on the flywheel side.
had this issue on my sol alot with every motor take the impact put it on loosen hit it for about 5 seconds put it on forward for 5 secs repeat over and over it will pop loose
/sig
There is a HONDA crank Pulley tool for this reason I have both for the civics' and accords .... you need a good 150 psi and a strong impact I have a Snap on 800ft and it takes everything off ....
If you don't have anything strong enough get that Crank pulley tool and a Big breaker bar and a exhaust pipe to extend your leverage .
