I have a 93 Ex coupe that I'm putting a 96-00 JDM D16 vtec motor and trans in. I know the dizzy wires are different and some sensors, can I just use z6 dizzy and the p28??? What other little things do I need to change?? Thanks in advance IA.
Work in progressneed slicks!
you can use the z6 dizzy and p28 as long as u stick w the obd 1 harness...but you also have to change the injectors as the 96-2000 are obd2a and injectors have different plugs...
Only thing you have to change is
dizzy
ecu
fuel injectors
