Results 1 to 17 of 17
Thread: 95 civic w/gsr swap injectors not workn
    Default 95 civic w/gsr swap injectors not workn
    Was driving fine symtomaticly actd like it ran out of gas...lookd at fuel pump first, its priming....checkd an it is getn fuel all the way to banjo on fuel rail.....plugs hav no gas on them so its not coming thru injectors, now idk if its the signal or mechanical.....relay an fuses are all good, dizzy is getn spark....im stumpd, tryd both p28 an 72 ecu
    Please lmk if u hav any ideas thanks
    Dec 2008
    Northside
    Unfortunately since the car is not obd2 it Wnt throw a check engine light for specific cylinder missfire. Check voltage to all injector clips, if all receive voltage then u need to check each individual inj.
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    Could be ecu , main relay
    Dec 2008
    Northside
    If it was the main relay I don't believe the pump would prime, correct me if I'm wrong
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    Privateer Racing!!
    Duluth,Ga
    Fuel filter.....duhhhhhhhhhhhhhhhh
    Main relay is good i hav 2 tryd both, as for ecu tryd 2 of them too an still same
    I dont think its the fuel filter...the gas is getn to the fuel rail
    Now that ive got the car home an hav ran better diag on it, doesnt look to be getn spark either....i went an got another dizzy (brand new) cant get spark off cap or plug....im thinkn my ecu has a bad ground or som'n ive tryd just about everything i can think of......any trouble shootn suggestions
    Btw this problem blows
    Dec 2008
    Northside
    and no CELs?
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    Well iab an knock, but i just havnt pin'd them yet, but no CEL, the ecu hasnt kept any codes, so that made me think it was just iab an knock i know those get lost aftr car turns off
    Dahlonega
    since nobody has said this...
    have you checked all your fuses under the dash, and under the hood on the pass side firewall?
    Dec 2008
    Northside
    He sayed he checked fuses
    Quote Originally Posted by Cynical 1 View Post
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    Ok i really got into it tonight, i got 12v goin to injectors, ALL grounds are good, clean all connections with electric cleaner
    When it died on road, was very unlike timing slip'd (was on the phone goin in a turn so i really dont know by the time i was on side of road it was over an i missd it lol) but i checkd anyway an WHAT DA YA KNOW broke timing belt....awesome i know
    So the question is now....do u think any damage was done...im not skill'd enough to take off head a check ive got a belt, an will get chain wrench 2mrrw an put on new belt....what do u think, is the head toast?
    Phone is actin like car sorry for double post lol
    Dec 2008
    Northside
    ive never experienced this, but just replace the belt, make sure timing is done correctly and if ur lucky there may be no damage, try that. and also find out what caused the belt to break, that isnt common to happen
    Quote Originally Posted by pacocrix View Post
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    9 out of 10 the valves are bent ...hell I seen a guy install a timing belt on a GOOD running car and first turn over it bent valves . So while you had way more rpms then 800 I am sure something is messed up . But I would always install a belt just to see might get lucky my friend
