Thread: Motor problems!!!
    Default Motor problems!!!
    Well i swapped a b18 block into my hatch..first i had the spark plug wires in the wrong firing order and it would not start..corrected it and replaced cap and rotor..car starts fine idles perfect but when i give it some gas it bogs and can't make it past 2k without cutting off..cel codes 54, 6, 10, 41. help!!
    Oh btw its a 96 hatch running p72 obd2, SI harness and head.
    buuuump
    barrow county
    "b18" block dosnt give enough info first of all. I DO HOPE its a gsr since p72 is a gsr ecu.
    if not a gsr, there is a problem.
    code 54: crank fluctuation sensor. bypass??? http://www.scribd.com/doc/2547345/Ho...F-Bypass-Trick
    for the other codes, i can only find them for obd1................. obd2 normally start with p------
    anyways.
    code 6: Coolant Temperature
    code 10: Intake Air Temperature (IAT)
    code 41: Oxygen sensor heater
    http://www.clubcivic.com/board/showthread.php?t=63326
    from experience, when map sensor is throwing off, you cant go pass 2k.
    -happen when i boosted my old 2000 ex and map sensor got unplug
    check your map sensor and tps plugs, might be mixed up.
    Quote Originally Posted by mitchworks View Post
    Damn right!! lol problem fixed..thanks man!!
    Certified Gearhead Thegrizz's Avatar
    Feb 2010
    Georgia?.
    hahaha.nice.weve all been their though.lol
    Del Slow?...
    J.R
    Down South
    Quote Originally Posted by Thegrizz View Post
    TRUE!
