Thread: Nothing over $30 sale, turbo, turbo parts, Ps pump, sway bar, Ls ecu, Del sol rims
    I ♥ Sluts
    Henry Co.
    Default Nothing over $30 sale, turbo, turbo parts, Ps pump, sway bar, Ls ecu, Del sol rims
    Greddy knock off blow off valve- $20
    Dumptube- $20
    Ebay turbo, no shaft play at all, but the hotside housing won't tighten down to stop from clocking- $30
    P30 B series powersteering pump with Unorthdox Racing pully- $25
    Boost solenoid, allows you to run boost by gear, no clue on the make- $30
    Integra front sway bar-$25
    Stock Del Sol rims, one is painted white, other is silver. Perfect for mounting drag radials on- $30
    PR4 Obd1 LS ecu- $20
    Best way to contact me is by cell- 678 977 1378
    1989 honda civic dx 4wslude's Avatar
    at a jack in a box
    Do you have the full set of del sol rims
    I ♥ Sluts
    Henry Co.
    Nope, just two.
    Hello, Need some more info on Turbo, size and what exactly is the problem? How much use out of it?
    CBE ENGINEERING CBEeng.'s Avatar
    Resaca, GA
    are the sol rims 15s or 14s i cant remember right off hand
    CRUDE BUT EFFECTIVE
    focussvt focussvt's Avatar
    Dec 2008
    georgia
    i need that ecu pm if we can meet up friday
    svt 3 gear killer
