I'm trying to get my buddy's accord running.
I swapped the oil pump for the CPS and swapped the dizzy and the intake manifolds all from the USDM f22.
Got everthing put in and hooked up. The car turns over, but it won't start. I don't hear the fuel pump priming when I turn the key, and when I took the fuel line off the rail and turned the key, no gas comes out.
I tried to jump the ECU and check the codes, but the CEL just stays on and doesn't flash. also, the CEL seems to be way dimmer than the rest of the cluster lights.
I have a ground on the thermostat housing, and the tranny, and the valve cover. I checked the fuses for the ECU, and the fuel pump and they aren't blown. Anybody have any ideas?
