Results 1 to 3 of 3
Thread: ::::::::::::::::::::::::IMAC 8,1::::::::::::::::::::::::::
    __DailyGrind
    Default ::::::::::::::::::::::::IMAC 8,1::::::::::::::::::::::::::
    SOLD!
    Rome, GA
    Is this one yours (20"?):
    Introduction Date: April 28, 2008 Discontinued Date: March 3, 2009
    Processors: 1 (2 Cores) Geekbench: 3317*
    Processor Speed: 2.4 GHz Processor Type: Core 2 Duo (E8135)
    Details: All Intel "Core 2 Duo" processors include two independent processor "cores" on a single silicon chip.
    Custom Speeds: N/A Architecture: 64-Bit
    Processor Upgrade: ZIF Socket FPU: Integrated
    System Bus Speed: 1066 MHz Cache Bus Speed: 2.4 GHz (Built-in)
    ROM/Firmware Type: EFI EFI Architecture: 64-Bit
    L1 Cache: 32k/32k L2/L3 Cache: 6 MB (on chip)
    RAM Type: PC2-6400 DDR2 Min. RAM Speed: 800 MHz
    Details: Supports 800 MHz PC2-6400 DDR2 SDRAM.
    How much RAM of what type do these systems support?
    Standard RAM: 1.0 GB Maximum RAM: 6 GB*
    Details: By default, 1 GB of RAM was installed as a single SO-DIMM module. One slot free.
    *Apple officially supports 4 GB of RAM, but third-parties have been able to upgrade the system to 6 GB of RAM using one 2 GB and one 4 GB memory module.
    Motherboard RAM: None RAM Slots: 2
    Video Card: Radeon HD 2400 XT VRAM Type: GDDR3
    Details: ATI Radeon HD 2400 XT graphics processor -- using PCI Express -- with 128 MB of GDDR3 video memory.
    Standard VRAM: 128 MB Maximum VRAM: 128 MB
    Built-in Display: 20.0" Widescreen Native Resolution: 1680x1050
    Details: This model has a 20.0" "glossy" TFT widescreen active matrix display with a native resolution of 1680x1050. Apple also reports a "typical" brightness of 290 cd/m2, contrast ratio of 800:1, and viewing angle of 160 degrees horizontal and 160 degrees vertical.
    2nd Display Support: Dual/Mirroring 2nd Max. Resolution: 1920x1200*
    Details: Apple reports that this model supports "digital resolutions up to 1920x1200" and "analog resolutions up to 2048x1536".
    Standard Hard Drive: 250 GB (7200 RPM) Int. HD Interface: Serial ATA (3 Gb/s)
    Standard Optical: 8X DL "SuperDrive" Standard Disk: None
    Details: Apple reports that the slot-loading 8X "SuperDrive" with 4X double-layer burning (DVD+R DL/DVD±RW/CD-RW) "writes DVD+R DL discs at up to 4x speed, writes DVD-R and DVD+R discs at up to 8x speed, writes DVD-RW at up to 6x and DVD+RW discs at up to 8x speed, reads DVDs at up to 8x speed, writes CD-R discs at up to 24x speed, writes CD-RW discs at up to 16x speed, [and] reads CDs at up to 24x speed."
    Standard Modem: None Standard Ethernet: 10/100/1000Base-T
    Standard AirPort: 802.11a/b/g/n Standard Bluetooth: 2.1+EDR
    USB Ports: 3 (2.0) Firewire Ports: 1 (400), 1 (800)
    Details: Three USB 2.0 ports, one Firewire "400" port, and one Firewire "800" port (7 watts each). Apple advertises that this system has "five" USB 2.0 ports, counting three on the system and two on the keyboard.
    Expansion Slots: None Expansion Bays: None
    Details: N/A
    Incl. Keyboard: Apple Aluminum Keyboard Incl. Input: Mighty Mouse
    Case Type: All-in-One Form Factor: iMac Core 2 Duo (Al)
    Apple Order No: MB323LL/A Apple Subfamily: Early 2008
    Apple Model No: A1224 (EMC 2210) Model ID: iMac8,1
    Details: Please note that these identifiers refer to more than one model.
    For more about these identifiers and how to locate them on each Mac, please refer to EveryMac.com's Mac Identification section.
    Battery Type: N/A Battery Life: N/A
    Pre-Installed MacOS: X 10.5.2 (9C2028) Maximum MacOS: Current*
    Minimum Windows: XP SP2 (32-Bit)* Maximum Windows: 7 (32-Bit, 64-Bit)**
    MacOS 9 Support: None Windows Support: Boot/Virtualization
    For more on running Windows on Intel Macs, please refer to the exhaustive Windows on Mac Q&A.
    Dimensions: 18.5 x 19.1 x 7.4 Avg. Weight: 20 lbs. (9.1 kg)
    Original Price (US): US$1199 Est. Current Retail: US$850-US$1000
    __DailyGrind
    yes sir with only thing different is the mouse.
