Thread: 95 civic with a6 swap no start
    Greene/Athens
    Default 95 civic with a6 swap no start
    Just finished up my swap in my civic. Fuel pump is coming on, there is spark. Haven't had a chance to check injectors yet. When I turn the key to the on position the cel comes on but does not go off like it is supposed to. What would cause this? Just a bad ground or??
    Thanks
    I Am, A Stunt Man
    starter?
    check the damn code.
    southside ATL
    edit: im a dumb ass. but yea check the code
    BABIES "R" US crew
    Greene/Athens
    Checked the codes, vtec spool and iat. A6 does not have vtec and there is no iat on my car. it probably doesn't make a difference but i'm running a p28/hondata s200. Couldn't get it to connect to my laptop either.
    RIGGER Sneezin's Avatar
    redtube
    haha well what does it do when you try to start it,,,,,no start,,, thats not much info.
    You using a vtec ecu, so you are gonna throw a cel because the ecu is trying to read vtec and it can not sense it. So I wouldn't worry about that, it should still start up with that ecu.
    try this:
    1. do a compression test
    2. check timing
    3. since the ecu is chipped, what map are you using?
