Results 1 to 20 of 20
Thread: crazy vtec please help!!!!!!!
    =) JF868849's Avatar
    Oct 2008
    BYRON
    Default crazy vtec please help!!!!!!!
    Ok I've got a eg coupe with a f20b dohc vtec with a h23 tranny stock motor ok so down to the problem when the motor/car is cold it pops vtec fine but when in warms up after like 5 mins it does not pop vtec at all?? Please any help would be greatly appreciated o and im running a p28 thanks
    oil pressure, dented oil pan, bad wiring, bad chip, bad solenoid etc ? vtec shouldn't work cold.
    Oct 2008
    BYRON
    My oil pan is dented could that really cause it? Do you think whatever its doing could be harming my motor?
    ran out of vtec kernels
    Oct 2008
    BYRON
    What are you talking about?
    Certified Gearhead JDMDA_1.7's Avatar
    that 90001!
    x2
    got vtec?
    Certified Gearhead b20vtecrr's Avatar
    Jun 2009
    423 chatt
    ran out of vtec kernels?????????????? horrible joke bro lolssssssss
    Jun 2009
    423 chatt
    def not needed
    locust grove
    yes a dented oil pan will cause it, what your problem is is that when your oil is cold it is thicker and your oil pressure is rising above 50 psi. when it heats up the viscosity changes as does your oil pressure, and with a dented oil pan the pickup may not be getting enough flow from the sump or it could be bent, i have personally seen that happen twice on honda's.
    this is dumb, but also check your oil level.
    as said before your vtec should not be working when the engine is cold, the gauge should be about 1/4-1/3 up off of the cold mark to allow vtec to operate, unless you have a vtec controller or other hackjob.
    if you do not have an oil pressure gauge, i highly recommend getting a cheapo sunpro that you can connect temporarily in the engine bay just to make sure that your pressure is up to par, dummy light wont come on until pressure is stupid low, iirc less 5psi or so
    check all your sensors and wiring, make sure there are no broken wires or shorts etc..., if you find no problem there i guarantee that your problem will be revealed with oil pan removed, trust me i almost tore a b20vtec completely apart because of low oil pressure and it turned out the pickup was a little bent
    Oct 2008
    BYRON
    Dang thanks man for all the help.I start trying different things
    Dahlonega
    vtec fluid is low.
    Oct 2008
    BYRON
    Quote Originally Posted by Cynical 1 View Post
    vtec fluid is low.
    Boy you guys are just to silly please keep the bs to yourself and thanks to the guys that are actually answering me seriously
    del sol? 94_teg_ls's Avatar
    since the motor didn't come in your car it could be low do a oil change mark your dip stick its probably got some tilt and you will not get a right reading
    /sig
    clean your vtec oil screen and make sure you have good connections
    I have fought many a vtec problems when overlooking a simple dented pan.. And vtec fluid = oil.
    Dahlonega
    someone gets it!!!
    i'm with the oil level being incorrect, or oil pressure being too low once it warms up.
    AccuracyPerformanceAutomotive
    x2!! I learned my lesson too, if the pan is dented I wont go any further. lol
    500whp of spinnin fury!!!
    Oct 2008
    BYRON
    Thanks guys for all the help I bought a new oil pan and pick up tube from mike johns aka h22 johns this weekend im gonna put it on tomorrow and see what I get
    Oct 2008
    BYRON
    Thanks to everyone that responded I fixed the problem it was the dented oil pan put another f20 oil pan on it and it pops perfect everytime now
