Results 1 to 15 of 15
Thread: 15x8 wheels questions ?????
    Blk SRT4
    Sep 2009
    Doraville-Atl
    Thumbs up 15x8 wheels questions ?????
    Hey I got a set of 15x8 wheels and I wanna put in civic ek 2.50 drop wat tires sizes I gotta use anyone kno the right sizes lmk thanks ....:
    ホンダ・インテグラ allout13's Avatar
    Dec 2008
    Cartersville
    195-50-15 probably would look the best
    also going to need a fender roll and probably a camber kit
    Feb 2010
    A-town
    if wheels have low offset get 195/45/15's
    Sent from my PC36100 using Tapatalk
    Blk SRT4
    Sep 2009
    Doraville-Atl
    Yea the offset is o
    Never go full retard
    Nashville
    No lower than 225, otherwise that 8 inches is a total waste.
    Certified Gearhead iamdallas's Avatar
    Aug 2010
    On a civic you're probably going to need to stretch 195's or 205's to fit the tire close to the fender. 225's will look too fat on a civic but that's a matter of opinion. I'll bet you'll want to go with 45's too.
    I'm pretty sure those are 195/45s for reference.
    ^^^but as he said when you go lower than 225s you are losing width of the wheel. 15x8s are kinda pointless on a civic unless you want some poke or something.
    Blk SRT4
    Sep 2009
    Doraville-Atl
    So wat the perfect size for mine 15x8 offset 0 195/45/15 , 205/45/15 , 225/45/15/ anyone kno ????
    Jan 2010
    We can do business
    if you are trying to make them fit the best and your purpose is looks then 195... if your purpose is traction then 225
    Aug 2010
    Quote Originally Posted by nelson9995 View Post
    ...and most likely 45's unless you aren't very low. You'll scrub like hell if you're too low and go with 50 series tires.
    It all depends on what you wanna do. But you can't really go too wrong with 195/45's.
    Newnan
    buy different wheels. you dont know enough to fit 8'' wheels yet.
    learn to english
    92 Hatch redneckhatch's Avatar
    White Castle
    I ran 195/50 on mine
    Blk SRT4
    Sep 2009
    Doraville-Atl
    Wat about 225/45/15 ?? Do I need roll the fender with those tires ??
    Blk SRT4
    Sep 2009
    Doraville-Atl
    WAT about 225/45/15 ?? Do I need roll the fender with those tires
    Aug 2010
    Quote Originally Posted by razo87 View Post
    Yeah. It won't even come close to fitting under the fender. The tire will stick out a TON. And if you're too low, you are going to SCRUB-udubub then pop a tire.
    You'll need a roll and maybe a pull.
    a Civic, 2.5 inches of lowering, and 8 inch wide wheels.
    you WILL have to get 195's and stretch, you WILL have to roll the fenders, you WILL have to induce A-lot of negative camber, and you most definitely need to get skinnier wheels
