Thread: NEED ADVICE HONDA CIVIC RUNNING HOT
    Lowrd S-dime
    gainesville
    Default NEED ADVICE HONDA CIVIC RUNNING HOT
    I HAVE A 96 CIVIC THAT IS RUNNING HOT ONLY WHEN YOU STOP BUT THEN COOLS DOWN WHEN MOVING. DONE REPLACED SOME HOSES AND THERMOSTAT. ANY ADVICE
    James-N-Tiff
    AccuracyPerformanceAutomotive
    Check your fans.
    500whp of spinnin fury!!!
    Lowrd S-dime
    gainesville
    fans are working as well. meant to mention that
    James-N-Tiff
    So when you come to a stop, the fans kick on, and it still runs hot? Maybe low on coolant/ air pocket?
    RIGGER Sneezin's Avatar
    redtube
    haha take the thermostat out and see what it does
    Norcross
    check your radiator cap. might be bad
    your moms house
    check cap sometimes the gasket goes bad thermostat mite be bad same shit happened to me and switch it and no more overheating
    (((((No more 4 door))))))
    Quote Originally Posted by Sneezin View Post
    should be running cool then
    Apr 2009
    warner robins
    fans arent workin
    your mom loves me
    redtube
    sooo.....?
    <--- RIP :,( psycho_freke's Avatar
    Locust Grove
    Try all posted above... double check that you didn't get a bad thermostat (put in pot of water with a meat thermometer and make sure it opens at 180...)
    Possibly and air pocket like stated above..
    x2 on checking the radiator cap..
    Are you sure it's your coolant fan that's coming on? You're A/C is off, right?
    Are the coolant fans coming on at the right temperature? Possibly a bad sending unit.
    When is the last time it was flushed? Possibly blockage? If nothing else works you may try a reverse flush in case something is clogged...
    Worst case scenario, check your head gasket... is it running rough? losing power? coolant (foam) in the head when you open the oil fill cap? Oil in the coolant?
    if you still cant figure it out i have a shop give me a call and ill take a look at it for you 678.500.5911
    new project every week.
