Results 1 to 14 of 14
Thread: Silvia parts, turbos, oem s13 silvia parts.....
    Someone call my lawyer... slyde_wayz's Avatar
    D.S.G.
    Default Silvia parts, turbos, oem s13 silvia parts.....
    Clean up sale. I have these items sitting around. All item price listed are negotiable unless stated otherwise.
    S13 Driver side and Passenger side doors. Neither doors ever disassembled.
    Door panles excluded.
    100.00 each
    S13 Driver side and Passenger side door panels.
    30.00 each
    Box projector headlights. Black housing.
    20.00 for the set.
    OEM S13 exhaust. Great condition.
    50.00
    JDM S13 Silvia Driver side fender. Has some dintage going on and the parts that bolts on the the front of the car is broken on one side. Can be welded or glued back.
    75.00
    S13 SE coupe trunk with oem wing.
    35.00
    S13 bumper support. Never hit lol
    20.00
    S13 A/C condensers. Little rough looking but no leaks.
    20.00 each
    S13 Silvia Dual Projector with inner fogs.
    170.00
    S13 Silvia Corner Lamps
    80 bucks each.
    S13 Silvia OEM Hood. Has nice size holes in it where previous owner i attempted to fit hood pins in it
    125.00
    OEM S13 Driveshaft
    20.00
    GT 38 Asking $700
    Turbo for a 94.5 - 97 7.3 Powerstroke.*This Turbo is a direct bolt-in.
    -capable of running up to 40PSI of boost
    -360 Degree*thrust bearing for max lubrication
    -Ported compressor inlet 1.10
    -Turbine housing A/R 1.1
    Next is a huge HUGE T4 GARRETT TURBO Asking $900
    BRAND NEW
    Compressor .58 A/R
    - 4" inlet, 2.5" outlet
    Turbine 1.11 A/R
    - T4 bolts are 2 3/4", and 3 1/4" apart , 4" exhaust
    Garett GT3782 Asking $850
    A/R .65 hot, 1.11 cold
    T4 flange
    GTP 38 W/Internal Waste Gate $750
    Powerstroke 7.3L GTP38 turbo off of a 2002 F-250. It has a 1.10AR compressor, and a .84AR turbine.
    Not gonna post a million pictures of the same item but you may make a request for me too on certain items. Just let me know.
    So Smoooth... Itll blow your teeth off!!
    That Fucking
    Jul 2009
    What else do I need to buy to install those box lights in my s13?
    D.S.G.
    Box lights are sold, but for future ref., all you need are the lights.
    That Fucking
    pmed lmk
    D.S.G.
    responded to fmn240
    That Fucking
    Unknown
    Jun 2009
    ill buy the hood where are you located?
    D.S.G.
    sold bro
    That Fucking
    Certified Gearhead 280zx 2by2's Avatar
    Nov 2010
    Valdosta GA
    PM'd about the trunk/wing however if you would just part with the wing that would be awesome.
    Teh rock smoker R3RUN's Avatar
    Atlanta,GA/Tampa,FL
    pm'd
    Pls tell me you still have the Silvia dual projectors and corners!!
    Unknown
    Apr 2009
    pm'd
    still have t4 turbo
    D.S.G.
    Bump for still having half of this shit lol. I finally moved back to Ga so hit
    me up.
    That Fucking
    Im leaking VTAKK!! Burnz1one's Avatar
    Pauldin County
    contact info?
