Thread: Instrument cluster went out?
    Atlanta, Ga
    Default Instrument cluster went out?
    So I've checked out the back of the cluster and everything is hooked up right, but for some reason just the gauge lights and a/c control lights are out. I removed one of the lights earlier today, but when I put it back in this happened. I've checked fuses and wires, but can't find anything wrong. Any ideas?
    Atlanta, Ga
    Omyfail. I just realized where I posted this. Lolol. I apologize. Please will someone move it to tech?
    LAWRENCEVILLE
    Check your fuses, Im willing to bet your taillights are not working when you turn the lights on aswell.
    Hella stock member!
    del sol? 94_teg_ls's Avatar
    Quote Originally Posted by silversol View Post
    x2
    /sig
    Atlanta, Ga
    Tail and tag lights work. I checked that fuse. Any other ideas?
    ive had this issue but it was the gauge harness i just replaced it
    /sig
    aye bro .:Stirfry:.'s Avatar
    rheostat or dimmer switch
    ATL DAsquad Member #9
    Atlanta, Ga
    i have LEDs bulbs in my cluster, and i removed one and put it back in yesterday and after that it wouldn't work. is it possible that one bulb could kill the whole circuit?
    i swapped the bulb back but it's been too bright outside for me to see if it fixed it or not lol. i'm thinking of replacing the dimmer i guess if this doesn't work.
    leds are polarity sensitive check them
    /sig
