Results 1 to 5 of 5
Thread: 94 del sol horn
    05srt4
    Jun 2009
    Upatoi, Georgia, United States
    Default 94 del sol horn
    everytime i try to use my horn it does nothing. i found the relay that clicks when u press the horn but it just clicks and clicks. replaced fuse and relay still does it. someone help?
    IA Member Mafdark's Avatar
    Feb 2011
    take a multimeter to the wires. check at the relay when someone hits it, if you get voltage start moving down the wires towards the horn. Relay may be busted or the horns may have been disconnected.
    05srt4
    Jun 2009
    i checked the horn its connected. could it be the parts inside the steering wheels?
    Dahlonega
    Quote Originally Posted by smart_ion View Post
    no, because they work - you hear the relay clicking.
    likely it's just the horn. check for voltage at the horn connector when someone is honking. voltage=bad horn.
    Feb 2011
    Quote Originally Posted by Cynical 1 View Post
    I wouldn't say it's likely the horn. The horns are probably the most simple component on a car, its not easy to break them so they don't work. But yes, check for voltage and tell us what you get. If you get voltage this could be an extremely simple fix.
    Little known fact; Del Sol Si and VTEC have two horns that create a lower pitched harmony. Del Sol S only has the higher pitch horn.
