Thread: gsr help
    Dec 2010
    gwinnett
    Default gsr help
    So i have a 94 gsr with a 98 B18c. I can turn on the car but when i press the gas it dies. I changed the map sensor and iacv but it still turns off when i give it gas. Wondering if anyone had this problem before?
    I Am, A Stunt Man
    have you checked your injectors? or fuel lines?
    Dec 2010
    gwinnett
    Yup checked those and they're fine. I installed a skunk2 manifold and i wonder if that has anything to do with it
    Certified Gearhead b20vtecrr's Avatar
    Jun 2009
    423 chatt
    im having a similar problem with my b16 bro when i start it and try to go it just bogs my cel code is for the tps sensor which is located on the back of the throttle body. your cel on?
    check for cel first...
    Jun 2009
    423 chatt
    ^^^^^^^^^^^^^^2 always, run a constant to the green plug itll tell you what your codes are
    <--- RIP :,( psycho_freke's Avatar
    Locust Grove
    Think it's possible that this could also be caused by a clogged fuel filter?
    People often overlook them and don't change them for years.
