Thread: 1991 Eagle talon AWD 53k orig miles, ksport coils, GT30r, Built 2.3
    Default 1991 Eagle talon AWD 53k orig miles, ksport coils, GT30r, Built 2.3
    Not really wanting to sell but I have a chance to buy another evo so this has to go. Can be tuned for the owner on whatever gas they want. Will make 500+ on e85 or 400 on pump gas....your choice. I did break the center diff a couple weeks back and is apart getting a welded one put in now. Other than that has run fine for me, the fans kick on by themselves and it doesn't overheat. Its almost as quiet as a stock dsm and is a very smooth. Pm with any questions. ASKING 7500 obo.
    PS:Will also part out if I get interested buyers in the big stuff also.
    Mod list:
    Engine
    Wiseco 8.8 compression .020 stroker pistons /w HD pin upgrade
    Eagle Rods
    King Race Bearings
    New 3rd Gen lifters
    New oil pump with BS elimination
    New 4G64 Crankshaft from Mitsubishi
    2.0 block Bored/hones line bored decked ect.
    Fully balanced rotating assembly
    Ported Polished head with GSC High tension Beehive springs with Ti Retainers and stainless steel seats.
    1mm oversize intake and exhaust valves.
    GSC S2 cams
    Metal HG with L19 Head Studs
    New water pump with new timing belt and tension installed 2 months ago.
    Fluid Dampner harmonic balancer
    JMF Race intake manifold
    Fluidyne Aluminum Radiator
    Progressive Fan speed controller with adjustable temp setting
    Setrab Oil Cooler with an lines and 1990 oil cooler housing.
    Fuel System
    FIC 1050cc injectors
    Supra intank fuel pump w/ rewire
    High flow Golan Fuel filter
    -6 an feed to rail from filter
    Aeromotive A1000 fuel pressure regulator with gauge
    Suspension/Brakes
    K sport Coilovers with race springs
    Poly bushings installed in suspension
    RRE upgrade front and rear sway bars.
    99 GSX Wheels with new tires
    Dual Piston Caliper upgrade brakes
    Electronics
    ECMLink V3
    GM MAF cable with 3 inch GM MAF
    3 bar Map sensor
    Innovative LC1 WB wired into ECMLink
    AEM TrueBoost controller /Boost gauge
    4 Point bolt in roll cage
    AlkyControl Full progressive Meth kit with 3 bar map sensor
    Battery relocation with Moroso Battery Box.
    Turbo and Exhaust
    Turbonetics Cast T3 manifold with External Tial 40mm wastegate
    GT3076r .83 T3 Turbo
    FP Feed and Return lines
    3 inch downpipe
    Apexi N1 exhaust
    Fully ceramic Coated turbo setup.
    Drivetrain
    TRE Stage 2 transmission
    Fidanza Flywheel
    ACT 2900 with Clutchnet 6 puck sprung disk
    4 bolt rear included. Not installed.
    New Shifter cables and Bushings
    dam dude thats a nice car glws
    Thanks man.
    Bump
    Make an offer need gone now I found something I want.
    Bump. Please do not pm if your not serious about buying I have no time to waste on idiots.
    Kabul, Afghanistan.. Xrated O.G.'s Avatar
    Troubleville, USA
    Location?
    The XUV !!!
    30 min south of atlanta. Price lowered to 6500 if the car sells before the one I want does.
    Gone lock it up.
