Results 1 to 4 of 4
Thread: Please help. HID kit issues
    Default Please help. HID kit issues
    I have a 2005 F-150 and installed a bi xenon H13 kit. The control harness that was included only feeds power off the passenger side headlamp plug and powers both ballast that way and leaves the drivers side plug open. Now, the problem I am having is the high beam indicator is always glowing and when switching to high or low beam, they do not work. Now, if I install a halogen bulb on the empty plug my high/low works, but its backwards! Low position is high and high is low. I also tried just wiring in a bulb (3157) on the high beam wire and ground on the open plug and get the same issue. How do I fix this? No one seems to know. Thanks for any help.
    Best led & Hid Store Raymond's Avatar
    Lawrenceville Georgia
    get a low resistor and plug into the empty socket. That should take care the problem. It needs current for the empty plug with your car.
    GP Thunder Pro HID kits
    Dome Lights-License Plate Lights-Angel Eyes Lights-Signal Lights...
    New DRL fog light in stock now! Please feel free to stop by!
    D1S (made in Korea) - D2R D2S Oem HID Bulbs - D4R D4S Oem Hid Bulbs
    GP Thunder - GOLDEN YELLOW 3500k - Plasma White 7500k - Plasma White with Ion 8500k made in Korea.
    http://www.hidlightsusa.com/
    http://www.importatlanta.com/forums/...play.php?f=228
    Thank you. And I should be clear, I did not get the kit from Raymond. I got it else where which I will not be doing business with again due to a lot of problems.
    Cool!
