Thread: crx keeps frying distributors
    east atlanta
    Default crx keeps frying distributors
    about a month ago my car was going dead randomly, but it would always start back up. then one day it went dead for good. i checked and it had no spark. so i put on a distributor from my other crx and it started right up. the car ran fine for about a week and then it went dead again today. i put another coil in it and it started up but sputtered a TON then went dead again.
    what should i check first?
    check your grounds, main relay, and ecu
    east atlanta
    main relay is good, i'll check my grounds tomorrow. the only other ecu i have is a crx HF..would that even start the car?
    sounds to me to definitely be either a short that killing your coil, or ground not making good contact. no clue about that ECU though.
    east atlanta
    Quote Originally Posted by DeeAOne View Post
    sounds to me to definitely be a either a short that killing your coil, or ground not making good contact. no clue about that ECU though.
    i'm gonna check the grounds tomorrow. i REALLY hope it's not a short in the wiring.
    btw, that 323 is awesome.
    anyone got an extra obd0 coil for sale?
    del sol? 94_teg_ls's Avatar
    i have one in a dizzy hiding in a pile in the garage
    /sig
    east atlanta
    Quote Originally Posted by 94_teg_ls View Post
    how much you want for that pile of garbage?
    you can pm me a offer ill go dig it out of all the ef parts
    /sig
    HF ecu will work if and only if your current engine in the CRX is dual point injection.
    east atlanta
    the HF uses MPFI, DX uses DPFI
    ALL CRX's are DPFI except the SI model, if yours is a HF and it indeed is MPFI, then it was converted either by you or previous owner
    east atlanta
    hah whatever you say dude.
