Thread: ls question
    THAONLYDAW/SISEATS
    Winder
    Default ls question
    ok i built a ls for boost with 9:5 pistons eagle rods pretty much fully built forged with head work cams and springs
    im running low on funds and was wondering how slugish it would be with out boost
    srp 9:5 pistons
    eagle rods
    stock polished crank
    block gaurd
    arp complete stud kit
    crower 404-6 with springs and retainers i wanna say like 475 lift intake and 477 exhaust or close to that
    major p&p
    all has been balanced and ready to go
    opinions please
    McDonough
    Kinda sluggish unless you get it tuned for this setup in an NA tune.
    Bitches love bacon.
    need more compression
    My line of work
    www.internationaljets.com
    Certified Gearhead dannysun's Avatar
    rome ga
    Quote Originally Posted by Starrfire View Post
    x2
    H22Turbo DC4 from a roll
    THAONLYDAW/SISEATS
    Winder
    the plan was to boost and make a whp goal of 425 but $ is low and at the moment i dont see myself purchasing a turbo so i was wondering how sluggish it would it be if i got a NA tune and ran it all moter
    if you cant afford to boost just yet, remove the cams and replace with stock cams for the time being... the 404's are going to make your life hell with sub 10 compression.
    There are no negative effects of boosting 10:1 engines. Its actually not a bad thing.
    My line of work
    true, but keep in mind he wont be boosting anytime soon due to tight funds. with his compression low and big cams, i recommended he replace the 404's with stock cams for the time being. makes sense eh?
    +1. The 404's will be counter productive with a low compression setup. I'd swap back to the stockers for the time being.
    As for the engine being sluggish, keep in mind that your compression ratio is still a tad higher than stock. It should run just like a stock LS engine.
    THAONLYDAW/SISEATS
    Winder
    Well the head is built around the cams....it has been milled .002 so it should be more to what 10:1
    The cams are all motor cams but after reading multiple dyno runs with them it's been noticed they respond very well to turbo se-ups as well that's why I went with them
    McDonough
    Quote Originally Posted by SX-MAN View Post
    But you aren't going turbo at the moment so you are back to square one. So, either swap the cams out and tune it for NA or just drop the money as you can to go turbo.
    Bitches love bacon.
    Loganville,GA
    I drove my SI around on 9:1 without the supercharger and it was annoyingly slow. You just have to get in the mindset it is just for transportation then it's not so bad.
    Mark
