Thread: Which motor for my hatch
    92 Hatch redneckhatch's Avatar
    White Castle
    Default Which motor for my hatch
    Right now I'm running a d15b non vtec jdm motor. I have d16z6 in my
    Basement I was just wondering what would be the better motor to build out of the two. I'm not looking for crazy numbers just something a little quicker then stock. I have heard good and bad on both motors so any input yall have will be really appreciated.
    Thanks in advance to all who respond
    z6, obviously. its .1 over the d15b non/v and uses larger bearings, IMO, better.
    have you considered doing a B series swap? a LS or B20 maybe? either will be a night day difference compared to now, and would run around if not 1k.
    Southside Ridin HATCH
    Between the two you listed... the Z6
    But like said above.. Swap that bitch out for a B series.
    More power, tq, also better format to build on in the future.
    White Castle
    Yea I had a b16a2 swap in my last hatch. Just don't have the funds right now for the swap. So that's why I was comparing these two motors since I already have both.
    Senior Member DustnU's Avatar
    I'm on a boat!!
    Keep the "D" you can kill B's with it if you do it right for less money. Z6 is by far better swap that in and get an ex/si trans if you don't have one. Google built "D" series and see what's been done out there. I did it a while back it's crazy.
    heres a few good build ideas.
    D16Z6 Bottom
    .020 over
    P29 Pistons
    H Beams w/ARP's
    Micro polished Crank balanced to 10K
    Eagle block guard
    D16Z6 Head
    Race Port & Polish
    Skunk 2 Valves
    Comp Zex Stage 2 Cam w/ springs and retainers
    Y8 ported intake
    H22 Throttle Body
    H22 injectors
    AEM cold air intake
    Pacesetter Header
    Chipped and socketed P28 tuned on CHROME
    Full MSD ingnition
    Findanza flywheel and clutch
    2 1/2'' Stainless exhaust
    93 Del sol si Tranny
    Motor put down 230 Crank HP/157ft lb at MEOVD engine Dyno in Zanesville.
    Work in progressneed slicks!
    I'm on a boat!!
    should be some help
    D16Z6 Bottom end
    -D16A6 (PM6 CRX Si) Pistons
    -Bored .040 Over (from 75mm to 76mm bores)
    -ARP headstuds
    D16Y8 Head (from 2000 Civic EX VTEC)
    -Crower Stage 2 Cam
    -Crower valve springs
    -Crower Titanium retainers
    -Skunk 2 Pro Series Intake Manifold
    -2 layer head gasket
    -AEM Adj. Cam gear
    -B16 Throttle boddy (58mm)
    -B16 Intake arm
    -Apex'i Power Intake
    -DC Sports 4-1 Headers
    -2.5 inch mandrel Exhaust with 22" resonator, SNL Twin Loop
    Tuned by Church, I put down 144whp, and 122 wtq.
    Quote:
    d16z6 block pinned and bored to 75mm
    75mm PM7 pistons
    B18b rods resized,polished, then shot-peened
    d16z6 crank balanced to above to 9k, allen plugs in crank throw oil gally's
    My d16y8 cylinder head that was posted here w/ fresh 3 angle
    59300 camshaft
    crower springs
    CBR 1000rr itb's
    310cc prelude injectors
    msd coil factory ignition
    arp hardware where available
    acl Race series bearings
    "the old one" oil pump mods
    made 172@7400 on 103 and 164@7253 on pump 93
    all done on less than $1,000......so y swap?
    White Castle
    ^^^ those are pretty good numbers for a d series. Now I think im going to go with the z6. Thanks for all the applys
    McDonough
    Keep the stock motor. Rebuild it. Run it another 200K+ miles. Keep good gas mileage. Make people jealous of said gas mileage.
    But.....since there is an option....build the stock motor. Do what few people do and build a D15B. Hell, make it a sleeper. Bore it to Z6 status and boost it.
    Bitches love bacon.
    IA Member FostyTG28's Avatar
    Jul 2010
    Have fun with it, no matter what you choose. Imo
    2001 Nissan Maxima SE
    1989 Ford Crown Victoria LTD
    Stay FROSTY
    locust grove
    they are right, you can make a d series really fun. just make sure you have an ex/si tranny, helps out a ton. have you thought about just putting vitara pistons and better rods and put together a budget turbo kit? 200+ hp is easily attainable with said mods. im sure you could do this for less than a dohc vtec swap, and you'll enjoy it MUCH more. i believe that you can run ls rods with a little bit of work to the block too..
    Putting together a B swap ISNT expensive..
    you just gotta know the right people!
    NA/Boost I got both. Supraboy87T's Avatar
    Jul 2009
    Check out my thread further down. Mine is a little more elaborate and I have more in mine though.
