Thread: high comp gsr
    in my house
    Default high comp gsr
    i have a gsr with its pistons. the current setup has about 130000 on it. i bought a kit. t3 t4 turbo. i was wondering if anybody has ever boosetd one? i kow the high comp an the its ring lands are a major factor. i want to find another block to build it but until then do this. i just want to get some feedback on this from people that has the knoledge about this. i mean i was thinking i could but no more than 5psi. which would still make power because of the high comp. i duno, just me thinking and reading. but me thinking is allways a bad thing. lol. im open to comments.
    i built a gsr last year with jdm itr pistons, i calculated the compression around 10:5-11:1 area w/ a standard OEM headgasket... with that being said, you could run 5 psi with a VERY good tune. also a cheap way to be safer is to get a thicker headgasket and ARP studs.
    what he ^ said
    E46 M3 Z0_o6's Avatar
    Suffolk, VA
    You can do it, just go with E85 as a fuel if you can. The detonation resistance will allow you to push it a lot farther than regular 93 octane. It's all in the tune.
    Who knows?
    in my house
    has the motor held up?
    in my house
    Quote Originally Posted by Z0_o6 View Post
    there is no way i can get e85 where i live so im stuck with 93. will add some octane boost every fill up i guess.
    No need for E85, just throw an 8psi spring in the gate, have it tuned and rock out. The weak ring lands are on the B16 pistons.
    MAINSTREAM PERFORMANCE
    Digital Box Tuning
