Thread: ecu and motor swap
    Certified Gearhead Go_Fast's Avatar
    Jun 2010
    I-575
    Question ecu and motor swap
    can you put a stock b18a motor and a pr4 ecu into a '95 integra gsr and have it run fine?
    if so what about the extra vtec wires?
    will it pass emissions?
    Dahlonega
    it will run.
    you will have to do some rewiring.
    emisions - only if everything is hooked up, and the engine is the same year or newer (with newer emissions exuipment installed), as they will check.
    Jun 2010
    I-575
    what if i get a b18 block, b16 head, and a stock p28?
    Quote Originally Posted by Go_Fast View Post
    it will run but not good. a p28 is for a d series. the engine set up will work but you need a different ecu.
    Jun 2010
    I-575
    Quote Originally Posted by blown_ss View Post
    what ecu should i get?
    by b18 do you mean ls or gsr? if you are doing a ls/vtec then you will need to get it tuned.
