Results 1 to 17 of 17
Thread: B18C bogging when VTEC engages
    South Side Georgia
    Default B18C bogging when VTEC engages
    Just did a swap. I took my sweet ass time, wired everything, conversion, everything is good. No CELS. I hit vtec 4500-5500 rpm and it starts to bog. The car itself sat for almost 2 years. I pumped good gas. I think it might be fuel filter but not sure.
    Feb 2010
    A-town
    timing
    Sent from my PC36100 using Tapatalk
    timing, ecu, dirty injectors, slow motor.
    IS300 NEMO's Avatar
    We Fuckin...
    did you check to see if there are any code or are you just going by there is no light on?
    Southside of The Jungle
    Also make sure dizzy coil is good,sometimes when they are about to go out they start doing that.If spark from cap is orange might have to change it.
    SOUTHSIDE
    cherrios the curse continues with u...
    this man has had about 3 cars and vtec has never worked
    ive seen his cars the vtec is wired right but still never works for him.......
    his last hatch he tryed everything to get it to pop vtec so at the end of it he put vtec on a button....lol
    IF YOU HAVE VTEC STAY AWAY FROM CHERRIOS HE WILL CURSE YOU......
    Quote Originally Posted by wrekonize View Post
    LOL. i always offer to help him, but he has alot of pride. he will learn eventually
    Southside Ridin HATCH
    Timing is right.
    his ecu, faulty injectors,maybe the intake is creating a weird wave stream between those RPM's causing a abnormality. maybe he just has bad luck? if i didnt have class today id come by and look at it.
    Yea. I think he tried using his ECU, from when he was boosted. Im not too sure tho.
    open it up, and remove jumper J1. drive it for a quick sprint and see what it does, it will run alot leaner but nowhere near dangerous.. unless its a turbocharged monstur. eh?
    Nevermind. I was thinking he was referring to HIS car.
    I just called him, he said Its his brothers. stock gsr integra with Skunk2 mani. Thats it.
    Hm.. I gotta go to work.. so I cant check it out either.
    d03z c4m iz 2 week 4 tat setup, b0ii!
    South Side Georgia
    My last hatch had a major wiring issue. I took the swap out n put it in the integra, wired vtec and it worked. Plus I had a busy job at the time.
    South Side Georgia
    timing is good, no need for tuning. Compression test was 230-245 all across. I think its a fuel issue.
    O rly?
    South Side Georgia
    O rly?
    Yes really sir
