Results 1 to 14 of 14
Thread: removing broken bolts?
    Default removing broken bolts?
    FML...unscrewed my cam caps and broke them so now I got got about 4 broken bolts in my head and one header bolt!!
    Well should I take it to the machine shop to remove broken bolts? Worth it? Or just get a new head? How much would it be to remove also
    Projects
    What head maybe just get a NEW head cause they will have to be machined out then retapped...
    Just an Ls head lol...jw how much it would be
    Projects
    Quote Originally Posted by Infamous_1 View Post
    Shit for that Head most shops i know would want $30-$50 a stud
    Greene/Athens
    x2. I just had to go through this with my head. luckily it was only one bolt.
    Oh well maybe just buy a new head then
    Mar 2010
    Africa
    Try to drill a hole in the broken stud and use a extractor bit...it took some patience but it worked for me. Gl!!
    Greene/Athens
    Quote Originally Posted by whoaitzbrain View Post
    you could try this but like he said be patient...very patient. just when your drilling through, be very careful and get the center and make sure to keep the drill straight. I ended up breaking the bit off inside of the screw that was already broken off in the head. Then you have to start cutting shit out.
    I would prob do that for the exhaust one but idk about the ones in the head...prob just get a new head....better then paying 200+ to take some studs out of a stock head. Any one got one fs? Lol
    just buy a a LS head used, they sell for 20-80 bucks tops for a bare head.
    Southside Ridin HATCH
    When you take your cam caps off..... there isnt any bolt sticking out to grab on to?
    Nope its in a hole and the bolt is only a 8mm
    IA Member Matt478's Avatar
    Aug 2009
    Macon,Ga
    i would also try the easy out bit,worked for me a couple times
    I will try the ez bit thing...but where do you get that at?
