Results 1 to 2 of 2
Thread: FS: Spearco Intercooler
    Northwest Georgia
    Default FS: Spearco Intercooler and other stuff
    I'm redoing my Intercooler so my old one is for sale. - $150.00
    Spearco Core - 20"x10"x4.5"
    End tanks can be re done to fit your application if need be, there are several shops that can do this for you. The driver side tank is flanged for a Tial 50mm BOV. Core supported an easy 800+ whp on a 2.0L b series engine so its still very well functioning.
    $150.00
    $150.00
    Vibrant 3" VanJen Connection System
    Brand new, bought the wrong size.
    $70 + Shipping
    ARP Head Studs
    GSR B18C1....Also works with LS VTEC setups
    Torqued a few times, just upgraded to stronger studs for the hell of it...these still hold just fine.
    65$ shipped.
    Catch can setup for sale...Bolts to a 96-00 civic driver side wheel well. It holds about a gallon and is baffled with 2 filters. It has 3 -8 ports on top that are where the AC dryer cylinder would usually be. I have 2 of the ports connected to the valve cover. Im selling the custom can with valve cover and lines to connect it. Pic doesn't show the filters in place because this was during fabrication...but there are 2 side by side, the same size as the "standard" catch can setups out there. It has a drain plug at the bottom.
    $350.00 ......
    GReddy Oil Sandwich Adapter
    USED, Comes with orings, -6 fitting, Honda oil filter center fitting. Great for an LSVTEC or TURBO setup for feed line or Both.
    $40 + Shipping
