Results 1 to 20 of 20
Thread: B series stuff
    Default B series stuff
    B series stuff
    1. P72 tapped oil pan SOLD
    2. 94+ GSR fuel pump with cage $25 tested working fine SOLD
    3. 94+ GSR fuel pump bare $10 tested working as well SOLD
    4. 4 NGK IZFR6K-11S stock #5266 NGK laser iridium spark plugs $10 obo
    Thing I need in trade –
    Hondata S300 with CD
    PS hose from a GSR 94 - 97
    Honda Part # 53713-ST7-A23
    DOHC Vtec valve cover
    GSR shift knob OEM
    Located near chamblee
    TTT
    make some offers need it gone just remember u need to come to get it. With gas over $3 can't travel out....
    TTT
    will take DOHC VTEC VCs in trade
    sold one fuel pump. spark plugs still have life in them, there the iridium type. the good stuff in normal temp range.
    Feb 2010
    Zebulon
    same part number for rs/ls/gsr for power steering pump line and sensor. any integra 94-01 line will work.
    Quote Originally Posted by xero_xero View Post
    The GSR has a diff part # hence i would like to obtain that piece. It's like selling someone a 94 coupe a/c hard line and you have you have a 92 hatch. It won't bolt up b/c the lines won't match up. They may look similar but honda designed those pcs just different enough that they won't bolt up. And in fact they do have different part #s. Yes a lot parts do interchange and my ride proves it - pwr window/ dr lock conversion, teg seats, type r mounts, eng swap etc. I have an actual Honda EPC so i can bounce around part #s to see for my self and they are diff part #s. Just don't know how there diff, right now.
    your real far if your based in Zebulon, do you travel close to Atlanta anytime? If you were selling a GSR pc i would be all over it but you have an LS and it's a dime a dozen.
    Feb 2010
    Zebulon
    http://www.rockauto.com/catalog/rafr...366445-3593999
    http://www.rockauto.com/catalog/rafr...366445-7910745
    just to double check, im calling acura as well. listed below are the pumps and rack and pinion. all of my searches are within the 1995 integra rs/gsr. ill call acura for the fun of it in the morining. Live in zebulon, work in powder springs. drive through down town every day.
    http://shop.advanceautoparts.com/web..._1002212807___
    http://shop.advanceautoparts.com/web..._1002234507___
    http://shop.advanceautoparts.com/web..._1002228720___
    http://shop.advanceautoparts.com/web..._1002206993___
    Feb 2010
    Zebulon
    and as for the part number, there is one available in the Atlanta Acura warehouse. next day pickup. 225 for the oem part that fits all trims. gave mine away today to a guy that bought the PS rack and pinion.
    5640-p2a-001 55.40 Pressure Switch
    53713-st7-a03 225 Power steering Pressure line fits all trims for a 95 integra.
    please double check everything you type before you post it.
    Your part fits LS and RS. 53713-st7-a03 - yours
    http://www.acurapartswarehouse.com/i...ca13st701.html
    Part i'm wanting
    53713-ST7-A23 - my part is slightly different part # wise
    http://www.acurapartswarehouse.com/P...gPicture=False
    You need to recognize there are different part # for the GSR vs LS/RS (94 - 97 models ) . I said they maybe interchangeable but the part # are different. The connections maybe the same but with slight differences between the two. Hence the different part number. Slight variations could be hose construction, angle of routing, etc. could be anything. Your saying that your LS part # (53713-st7-a03) will work in place of a GSR part # (53713-ST7-A23). I am saying that its a possibility. But the part #s are different and i prefer the GSR over the LS. I'm not saying it won't work But my a/c line example above is what could happen. B/c there is a part number difference i prefer the GSR 94 - 97. For the 98 and up i can see the part # did indeed change. Why - maybe slight improvement, hard to say unless i see the part.
    Yes, autozone may use the same part b/c the fitting is the same but theirs maybe universal, hence one part fits all. Not a big fan of autozone / pepboys replacement branded parts though. I prefer OEM for good reason. There are rare exceptions, though. I.E. Denso (supplier to Honda) remanufactured replacement part sold through autozone. Even then i research it...first.
    I should know part number differences my EPC helped my build on paper what i needed (motor runs so that is a good sign, lol) -
    water valve HOSE A, WATER INLET 79721-ST7-000 1 14.68 14.68
    front fender cover clip 91516-SK7-013 6 2.81 16.86
    Engine wire harness clamp 2 CLIP, HARNESS BAND (145.2MM) (NATURAL) 91540-SV4-003 2 3.17 6.34
    control unit engine room fuse label 38253-ST7-A01 1 4.97 4.97
    P.S. pump Power steering pump seal 91249-p02-003 1 5.24 5.24
    P.S. pump O-Ring (5.8*1.9) Nok 91317-P02-003 1 0.92 0.92
    P.S. pump O-Ring (13.0 * 1.9) 91345-Py3-000 1 1.1 1.1
    P.S. pump O-Ring (22.1*1.9) Nok 91346-Py3-000 1 1.1 1.1
    P.S. pump O-Ring (16.8*1.9) Nok 91347-Py3-000 1 1.11 1.11
    P.S. pump O-Ring (54*1.9) Nok 91348-Py3-000 1 1.82 1.82
    P.S. pump O-Ring (68.5*1.9) Nok 91349-Py3-000 1 2.21 2.21
    water hose Electronic Air control valve In 19506-P72-000 1 3.75 3.75
    water hose Electronic Air control valve Outlet 19507-P72-000 1 7.37 7.37
    water hose Bypass outlet hose 19508-P72-000 1 3.19 3.19
    water hose breather heater hose A 19527-P72-000 1 6.02 6.02
    P.S. hoses pipes Power steering feed hose 53713-ST7-A23 1 122.12 122.12
    Breather chamber O-ring (29*2.5) 91324-PR3-003 1
    Engine wire harness clamp distributor clamp 1
    High tenssion cord spark plug Spark plugs PFR6G-13 NGK 98079-56A7H 4 13.76 55.04
    Cylinder head cover head cover gasket, B 12342-PG6-000 4 2.04 8.16
    Breather chamber BULK HOSE, VACUUM (7.3 X 3000) 7.3 X 120 95005-75003-10M 1 34.85 34.85
    Unknown distributor seal Unknown 1
    Camshaft-Timing Belt cover Timing belt 14400-P72-014 1 39.41 39.41
    Camshaft-Timing Belt cover timing tensioner 14510-P30-003 1 58.39 58.39
    Water pump sensor Waterpump 19200-P72-003 1 91.45 91.45
    Camshaft-Timing Belt cover Cam seals 91213-PR3-004 2 5.34 10.68
    Cylinder block - oil pan Oil pan gasket 11251-P30-004 1 21.35 21.35
    Cylinder Head INTAKE VALVE SEAL 12210-PZ1-004 1 11.6 11.6
    Cylinder Head EXHAUST VALVE SEAL 12211-PZ1-004 1 11.6 11.6
    Cylinder head cover head cover gasket 12341-PR3-000 1 8.21 8.21
    Cylinder head cover oil filler gasket 15613-PC6-000 1 2.89 2.89
    Distributor dist O-ring / housing (O-RING 26.4X3.1) 30110-PA1-732 1 1.41 1.41
    Oil pump - oil strainer cooler Oil O-ring / hoses 91316-PT6-003 1 1.91 1.91
    Oil pump - oil strainer Oil strainer gasket 15221-PW0-S01 1 1.63 1.63
    Oil pump - oil strainer front crank seal 91212-PR3-003 1 6.64 6.64
    Valve rocker arm O-RING VTEC (O-RING 6.8X1.9) 91306-PJ4-000 2 1.09 2.18
    Water pump sensor Coolant back pipe O-Ring 91314-PH7-003 2 1.58 3.16
    Unknown distributor bearing Unknown 1
    Cylinder head Cam seal end plug (cyl head seal) 12513-P30-000 1 5.16 5.16
    Cylinder block - oil pan Rear main 91214-PH1-013 1 12.62 12.62
    Breather chamber Breather O-ring hose (grommet breather chamber) 11853-PR3-000 1 2.03 2.03
    Breather chamber PCV VALVE GROMMET 11855-P72-000 1 2.94 2.94
    Breather chamber PCV TUBE C 11857-PR3-000 1 4.04 4.04
    Breather chamber PCV valve assy 17130-P72-003 1 13.75 13.75
    Camshaft-Timing Belt cover Timing belt cover heat, insulator 11836-P72-000 1 11.39 11.39
    Camshaft-Timing Belt cover Seal rubber lower 11831-PR3-000 1 18.09 18.09
    Camshaft-Timing Belt cover Engine mounting bracket rubber, seal A 11925-P30-000 1 4.48 4.48
    Camshaft-Timing Belt cover Engine mounting bracket rubber, seal B 11926-PR3-000 1 3.4 3.4
    Crankshaft-piston Piston rings GSR STD 13011-PR3-004 4 28.37 113.48
    Crankshaft-piston THRUST WASHER 13014-PR3-S20 1 10.41 10.41
    Crankshaft-piston Connecting Rod (1) brown 13213-P72-003 2 9.57 19.14
    Crankshaft-piston Connecting Rod (2) green 13214-P72-003 2 9.57 19.14
    Crankshaft-piston Connecting Rod (3) green 13214-P72-003 2 9.57 19.14
    Crankshaft-piston Connecting Rod (4) green 13214-P72-003 2 9.57 19.14
    Crankshaft-piston Main bearing upper (4) brown 13323-PR3-004 1 9.92 9.92
    Crankshaft-piston Main bearing upper (1) green 13324-PR3-004 1 9.92 9.92
    Crankshaft-piston Main bearing upper (2) green 13324-PR3-004 1 9.92 9.92
    Crankshaft-piston Main bearing upper (5) green 13324-PR3-004 1 9.92 9.92
    Crankshaft-piston Main bearing upper (3) YELLOW 13325-PR3-004 1 9.92 9.92
    Crankshaft-piston Main bearing lower (4) brown 13343-PR3-004 1 9.92 9.92
    Crankshaft-piston Main bearing lower (1) green 13344-PR3-004 1 9.92 9.92
    Crankshaft-piston Main bearing lower (2) green 13344-PR3-004 1 9.92 9.92
    Crankshaft-piston Main bearing lower (5) green 13344-PR3-004 1 9.92 9.92
    Crankshaft-piston Main bearing lower (3) yellow 13345-PR3-004 1 9.92 9.92
    Cylinder head Filter assy, Spool valve 15825-P08-005 1 13.41 13.41
    Cylinder head GASKET, SOLENOID BASE 36172-P08-015 1 5.57 5.57
    cylinder head vtec gasket pressure switch broken (O-ring) 91319-PR3-003 1 1.73 1.73
    cylinder head CAM HOLDER O-RING 91302-GE0-000 1 1.56 1.56
    cylinder head Cylinder Head Gasket 12251-P30-014 1 65.98 65.98
    Cylinder head cover Head cover bolt B 90012-PM7-000 1 3.2 3.2
    Cylinder head cover IGNITION WIRE CLAMP , STAY B 32762-PR3-000 1 2.68 2.68
    Cylinder head cover IGNITION WIRE CLAMP , STAY C 32770-PR3-000 1 2.68 2.68
    Cylinder head cover Head cover nut 90212-PR3-000 4 2.1 8.4
    Engine wire harness clamp Oil pressure switch 37240-PT0-023 1 15.45 15.45
    Intake manifold Intake Gasket 17105-P72-004 1 10.27 10.27
    Oil pump - oil strainer Oil pump O-ring 91302-PF0-003 1 1.4 1.4
    throttle body Throttle body gasket 16176-P30-004 1 3.92 $3.92
    Valve rocker arm lost motion c-clip( lost motion assy) 14820-P30-010 1 24.15 24.15
    Water hose Oil cooler hose In. 19422-PR3-000 1 9.62 9.62
    Water hose Oil cooler Hose Ex 19423-P72-000 1 7.64 7.64
    Water pump sensor Thermostat 19301-P08-316 1 16.49 16.49
    Oil pump - oil strainer oil pump assy Type R 15100-P72-A01 1 101.05 101.05
    Camshaft-Timing Belt cover Timing belt cover heat, insulator obd2 11810-P72-A00 1
    Camshaft-Timing Belt cover r. BACK SEAL, RUBBER 11832-P72-000 1 27.94 27.94
    Camshaft-Timing Belt cover timing cover bolt lower 90007-679-000 5 2.87 14.35
    Camshaft-Timing Belt cover 2 bolts upper timing cover 90010-PR3-000 2 3.2 6.4
    Camshaft-Timing Belt cover lower timing cover 11810-PR3-010 1 35.34 35.34
    Camshaft-Timing Belt cover timing tensioner plug 11812-PJ7-310 1 2.78 2.78
    Camshaft-Timing Belt cover Upper timing cover 11820-P72-000 1 31.41 31.41
    Camshaft-Timing Belt cover gasket lower timing cover 11831-PR3-000 1 18.09 18.09
    Crankshaft-piston Timing belt drive, Pulley 13621-PR3-003 1 31.18 31.18
    Crankshaft-piston Timing belt guide plate 13622-PR3-000 2 3.26 6.52
    Cylinder head Solenoid assy 36171-P08-005 1 125.82 125.82
    Cylinder head vtec gasket pressure switch broken (switch assy valve timing oil pressure) 37250-PR3-003 1 49.46 49.46
    Cylinder head cover HEAD COVER WASHER 90442-P30-000 8 3.28 26.24
    Cylinder head cover Cap nut (chrome 6mm) 90213-PH3-000 8 2.29 18.32
    Cylinder head cover Valve cover gasket set (Head cover gasket set) 12030-PR3-000 1 40.95 40.95
    Distributor Cap Assy. 30102-P72-006 1 18.13 18.13
    Distributor Rotor Head Assy, kit 06304-P72-000 1 16.76 16.76
    High tenssion cord spark plug Ignition wire 32722-P30-000 1 50.36 50.36
    Oil pump - oil strainer sealing washer (18MM) 15234-PC6-000 1 2.54 2.54
    Valve rocker arm sealing washer (20MM) 12209-PR3-000 2 2.01 4.02
    Well if you still have the LS one, i may hit you up......
    Feb 2010
    Zebulon
    that is an outdated part. that was replaced by the current part above. Cheers!
    Not according to below - 53713-ST7-A23
    I'll call on monday to see what the current part # is. All my sources tell me it's still 53713-ST7-A23 for 94 - 97 GSR. Usually the website is good about discontinuing parts and superceding. I.E. 12513-P72-003 vs. 12513-P30-000. The first one is a old version and superceded to the second part and it proves it on the website. These were the original cam seals that were rubber and switched to the push in plug style. I actually have both, lol.
    So thats why i think they still sell the GSR version. For the 98+ i think they did the same thing when i look real quick....
    http://www.acuraautomotiveparts.org/...s=&view=normal
    Feb 2010
    Zebulon
    the site, is a dealer based site. this is not a direct reference to any parts sources within Honda Motor Corp. everything on there is republished but not entirely complete or accurate as stated in their disclaimer.
    please use complete and accurate references when sourcing or publishing information. Cheers!
    all information acquired needs to come from Acura or Honda dealer parts locater which is only accessible by Parts Associates and Techs.
    Yep i will contact two dealers on monday to verify my GSR part # is still active and orderable and hasn't superseded to your RS/LS part # you refer too. Whatever the parts guy tells me i go with. Nothing more, nothing less. Till monday.
    So i called 3 dealerships for my part - 53713-ST7-A23, my GSR part, is valid and orderable and in stock in a wareouse. All 3 said part # is good and i can get in one day. This validates my point that the online oem acura site is upto date as far as orderability. The prices below is the price quoted by the dealership over the phone or online. Why the discrepancy in price b/c dealerships charge whatever they want, MSRP vs some discount. Since my part # is still valid for 94 - 97 GSR, i've proved my point that it is a good part number i can order today. Your part # 53713-st7-a03 is LS / RS like i said. My Honda EPC rarely lets me down, b/c it's actually what the parts guys sees on his screen. They may have updated software but it's the real deal. Next time i'm up there i should look, lol. Now did you call acura to see what the deal is for my part # vs your part #? Is my part # 53713-ST7-A23 obsolete as you claim it to be? You should find your LS part did not supercede my GSR part #. Let us know what you find.
    53713-ST7-A23
    Delray acura - (561) 265-0000 http://www.acuraoemparts.com/delray/...1=&inputstate=
    Price - $122.12 online
    Acura Carland gwinnett (770) 623-9211
    price $226.01
    Ed Voyles Acura - (877) 297-7172
    price - $206.19
    Like i said before RS/LS (53713-st7-a03 ) part may work but i prefer GSR part (53713-ST7-A23). Pepboys / Autozone maybe universal, that is not unual.
    The resources i use are genuine Acura OEM parts suppliers located at dealerships selling genuine parts. Yes some are online only but i check real brick and mortar as well. You can not get any real than those websites. Occasionally parts are obsolete but very rare from what i've seen. And my part #s come from a Honda EPC which is a genuine resouce that parts counters employees use behind the counter. Maybe slightly obsolete but it's the real deal b/c it even cross references where that part used on differnt platforms, etc. It's good stuff...
    CHEERS, I've done my homework LOL.
    ttt
    ttt
    add OEM GSR shift knob i can take in trade
